Learning the GL2 at DVinfo.net
Old April 18th, 2005, 01:16 PM   #1
Learning the GL2
Is there a tutorial video out that teaches how to setup and use all the funtions of the GL2? I know this site has tons of info, but I don't know exactly what I'm looking for. I'm new to video cameras and I'm just interested in some step by step hand holding. If there's not one, someone should make one. I would hate to shoot a bunch of video only to find that it would of been better if I had some settings adjusted or should not of had it in frame mode, etc.
Adam Bray is offline   Reply With Quote
Old April 18th, 2005, 04:07 PM   #2
Fred Retread
I was going to reply that the owner's manual is the closest thing you'll find. Not so. I found this with a google search on "GL2 tutorial."
http://www.filmwareproducts.com/DMTS...TSSFTCcan.html
However, the owner's manual is still a good place to start, and by all means do some experimenting.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply With Quote
Old April 19th, 2005, 06:34 AM   #3
I've commented about this "Shoot for the Cut" video before. I purchased it some time back, and was disappointed in it. It's not much better than a careful reading of the manual.
Jim OMalley is offline   Reply With Quote
Old April 19th, 2005, 03:01 PM   #4
Fred Retread
Not surprising. Thanks, Jim. It wasn't high on my list but I might have gone for it.
Old April 19th, 2005, 11:37 PM   #5
Old Boot
Best tutorial? use Manual functions and then preview your work using the DATA to output and SEE your numbers on the BIG tv screen! Works for me!
Grazie
Old April 21st, 2005, 01:01 AM   #6
Grazie
100% with you on this one Grazie, see you are officially an old boot :)
Hope you are having fun with your XM2's, may catch up with you next week at the IOV convention if you are going
Alan McC
Alan McCormick is offline   Reply
