soft case GL2 at DVinfo.net
Old October 15th, 2002, 10:07 AM   #1
soft case GL2
I am looking for a soft case for the Canon GL2. It should be compact but give enough protection and have some space for an extra battery, tape etc.
Hans Kuipers is offline   Reply With Quote
Old October 15th, 2002, 10:13 AM   #2
I have a Kata CCC-102 from Zotz. So far, so good.
Sandy
Alexander McLeod is offline   Reply With Quote
Old October 15th, 2002, 11:57 AM   #3
I'm looking for a backpack
I've been looking for a not-too-large backpack that will carry a GL2 and possibly a 35mm SLR with a medium zoom lens attached.
So far, no luck.
Tom Hill is offline   Reply With Quote
Old October 15th, 2002, 03:57 PM   #4
to Alexander McLeod
I looked at the Kata CCC-102 soft case. To me it looked very big to carry around. Is the Kata ccc-101 not a more convient case to carry the GL2 around??????
Old October 15th, 2002, 05:16 PM   #5
The Kata CC-101 is perfectly sized for the GL2 and is the largest case I'd care to carry around all day.
Old October 15th, 2002, 05:21 PM   #6
Because I prefer to carry my GL2 incognito I stuff it in what looks like a men's oblong rectangular vinyl black shaving kit bag. The large 941 battery is attached to the cam before I take it anywhere and the wide angle adapter and a couple of DV tapes and smaller batteries will fit snugly in the bag. My GL1 is toted in one of those blue insulated lunch thingys from Kmart/Target department stores. None of my cams have ever been stolen because no one has a clue whats in the bag, unless they assume it is lunch. Water protection as well as protection from heat and cold is also a big plus with the boxy insulated (cloth/foam rubber?) lunch carrier. I can take my GL2 anywhere and feel confident it won't sprout legs and dissappear. Both bags have shoulder straps so dropping either bag is out of the question and the bag itself is tucked under the arm to protect against banging other objects. I do not encourage anyone to do what I do, but I have good cam bags and only use them occasionally. They are not as air tight.
The GL2 is at least 1/2" longer than the GL1 so it will not fit well in the blue lunch box. Darn...
Bill Hardy is offline   Reply With Quote
Old October 15th, 2002, 05:42 PM   #7
I just ordered the Lowepro Vidcam 6 today. I decided on the 6 over the 5 because I prefer to keep my WA adapter on at all times. With the WA's hood and the large eyepiece, the cam measure 15 inches. The Vidcam 5 states up to 13", the Vidcam 6 up to 16", so VOILA!! Cost $48. Tell you how I like it when I get it.
I have been keeping it in a 16" tool bag from Home Depot($39). Padded it with some foam from Joanne Fabrics($4). It is a bit heavy though and if you are just looking for transport from here to there, pretty neat. It has like 8 inside pockets as well. Hopefully the Vidcam 6 will feel a bit smaller.
Michael
Michael A. Davis is offline   Reply With Quote
Old October 15th, 2002, 05:51 PM   #8
Re: to Alexander McLeod
<<<-- Originally posted by Odessadream : I looked at the Kata CCC-102 soft case. To me it looked very big to carry around. Is the Kata ccc-101 not a more convient case to carry the GL2 around?????? -->>>
The CCC-102 is several inches longer than the GL2 but it does allow room for the WD58H and hood, lens filters, spare battery, wireless controler, and the like. After lugging around a large bag for my EOS5 with assorted telephoto lenses, etc this is a piece of cake. The only problem I foresee is when I ski: I will have to transfer some of the gear to a backpack. When I'm sailing I just store the bag in a secure spot below.
Sandy
Old October 17th, 2002, 11:16 AM   #9
alternative case ???
what about the Lowepro Vidcam 5???
Old October 18th, 2002, 09:47 PM   #10
Re: alternative case ???
<<<-- Originally posted by Odessadream : what about the Lowepro Vidcam 5??? -->>>
I haven't seen the Lowepro in the flesh, so to speak, but I think that would be a very good alternative. I'm new at the serious videocam game so I went with the suggestions of those who are much more experienced than I.
Sandy
Old October 21st, 2002, 12:06 PM   #11
Got the Vidcam 6. Way too big. Gigantic.
Returned and got the Vidcam 5. Just right.
With the WA and hood and lrg battery, the camera slides right down nice and easy with a little bit of push on the side walls but certainly nothing to worry about. This bag is just the right size.
Michael
Old October 21st, 2002, 12:40 PM   #12
to Michael Davis
thanks for your opinion Michael. I also had the feeling that the no. 6 was a little to big. Glad you confirmed my hunch :-)))
Old January 4th, 2003, 11:39 AM   #13
Have you bought the vidcam5 already?
What are your thoughts?
Dirk
Dirk Goris is offline   Reply With Quote
Old January 4th, 2003, 01:42 PM   #14
Re: soft case GL2
Yo, i have a Trekking 220 (samsonite)
There is plenty room for xtras
greetz
Erwin
Erwin Kolman is offline   Reply With Quote
Old January 5th, 2003, 07:09 PM   #15
I am using the vidcaom 5 with my GL2. It's just perfect. All what it comes with the Gl2 plus the BP-945 battery and still there is more space
Zaid_Malaika is offline   Reply
