Lens question at DVinfo.net
Old November 7th, 2002, 07:58 PM   #1
Lens question
I'm looking to get a filter for the GL2. I'm interested in one that can stay on for protection, with minimal distortion.
I'm looking at the B + W 58mm filters. The choices (regular, not slim) I've been looking at so far include the following:
strong UV haze 415 glass filter;
UV haze 010 (MRC) Multi Resistant Coating glass filter;
UV haze 010 glass filter; or
UV haze 010 flass filter extra wide.
Does anyone have recommendations as to which filter best meets my needs?
Stephen
Stephen Sobel is offline   Reply With Quote
Old November 8th, 2002, 04:02 AM   #2
Outer Circle
Get a slim line. It might be closer to the lense thus less reflection and distortion.
I didn't know they have so many variations of the UV 010.
Maybe this one?
or a Heliopan UV? (slim line)
But what's wrong with a Cokin or Hoya? For a UV protection filter for a video cam, you don't have to go with the most expensive.
[IMG]www.dvfreak.com/filters.htm[/IMG]
Old November 9th, 2002, 08:07 PM   #3
I'm not familiar with either the Cokin or the Hoya. How do they compare to the B + W or Heliopan in terms of distortion?
Old November 9th, 2002, 11:37 PM   #4
I use Hoya filters for my Canon 35mm SLR and I see no distortion in my film.
I havn't tried any Cokin though.
Jim Yang is offline   Reply With Quote
Old November 9th, 2002, 11:45 PM   #5
Outer Circle
B+W and Heliopan are both owned by the same company, and both use the same German glass. No difference.
I have Cokin filters, and I like them better than the Heliopans, B+Ws, Nikons etc. I've heard that Hoya filters are also very good. Regarding specialty filters, that's more subjective and another story.
Old November 10th, 2002, 07:53 AM   #6
Is there a difference in distortion/video quality between multicoated filters versus regular filters?
Old November 10th, 2002, 08:45 AM   #7
Warden
The difference varies from nominal to extreme. Your safest bet is to always use a multi coated filter unless you can guarantee with 100% certainty your lighting conditions. Single coated filters will show varying degrees of flair the more you point your lens toward a bright light source. Single coated filters also tend not to be manufactured to the same standards as the more expensive multi coated filters. Bottom line , best investment and most bang for the buck, multi coated filters.
Jeff
Old November 11th, 2002, 12:19 PM   #8
I have the multi-coated B+W and it lives on my GL2. I avoided the slimline becase it does not have threads on the external side so the lens cap would not stay on unless you by a new lens cover.
Keith Luken is offline   Reply With Quote
Old November 11th, 2002, 01:43 PM   #9
Yeah I got the slimline Heliopan UV and I have that problem with the lenscap, staying on, but the stupid clip on the cap presses up against the lens - and yeah it does mark the filter :(. Even with the non-slim Heliopan the same problem occured, so I just stuck with the slim one. I will need to get another cap, or I will put a thin layer of felt on it.
Aaron Koolen is offline   Reply
