GL2 not responding to "print to video" command at DVinfo.net
Old August 23rd, 2005, 05:41 AM   #1
I have recently experienced a problem with trying to "print to video" while using my GL2. I am suing Final Cut Express 1.0.1 with it installed on an ibook with superdrive. FCE does see the GL2....I can capture footage with no problem.
For print to video I:
Go to "print to video" and click it.
A screen pops up that says start record on camera.
I click record on my GL2 but nothing happens.
I do not see any image on my GL2's flip out monitor screen. It is just black. Now if I click the GL2 off, then to vcr mode I can see the movie I'm trying to capture play for a second then it goes to black.....
Anyone have any suggestions?!?!
thanks!
Dennis Parker is offline   Reply With Quote
Old August 23rd, 2005, 08:10 AM   #2
Fred Retread
Dennis,
The GL2 should be in VCR mode to begin with. Sounds like you were in camera mode and pressed the red button.
This is covered on page 99 of the manual, but in case you don't have it handy:
  • Keep the cam off when connecting or disconnecting the DV cable
  • With the DV cable hooked up, turn the cam on in VCR mode. You should see "DV IN" in the display.
  • press the record/pause button on the top of the handle. The cam is in record mode, but waiting.
  • When the program prompts you to record, press the >/|| (play/pause) button on top of the handle.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply With Quote
Old August 23rd, 2005, 08:45 AM   #3
Fred,
Thanks for the info....I'll try it this afternoon after I get off work!
Old August 23rd, 2005, 02:10 PM   #4
Originally Posted by Fred Retread
Dennis,
Fred,
Thanks for pointing me in the right direction. I used your instructions above to guide me. My problem was at the "DV IN" stage. My screen said "AV>DV". I clicked on my GL2's menu and went into "VCR SET UP". I scrolled down and changed the correct setting to "DV IN". Problem solved!
I would not have figured this out without your help. I truly appreciate it!
Have a great day!
