GL2 External Mics at DVinfo.net
Old January 14th, 2006, 06:39 PM   #1
GL2 External Mics
Hi all,
My DM-50 works great. However, when I plug in a lapel mic or other mic the audio barely registers. I tested the mics with the computer and they are good. What am I missing?
Glen Tibbits is offline   Reply With Quote
Old January 15th, 2006, 05:43 AM   #2
Do the other mics require power?
What is the external mic jack sensitivity setting (is MIC ATT on)?
What is their output impedance? The input inpedance of the GL series mic jack is about 600 ohms. Some mic have a higher output impedance and this will result in the loss of level - it can be significant if the mispatch is high.
Some mics have a fairly low output level.
dpalomaki@dspalomaki.com
Old January 15th, 2006, 07:56 AM   #3
i use a rode videomic, which works brilliantly. but the videomic uses a 9v battery and i dont think that most lapel mics are powered, and the gl2 doesn't provide power (unless you use a phantom xlr adaptor).
just wondering - what does the mic att actually do?
Harry Marr is offline   Reply With Quote
Old January 15th, 2006, 08:54 AM   #4
mic att.
I believe the mic att. "pads" the input of the mic...so that if you're recording in a very loud environment you don't clip the sound recorded.....like with a factory or a rock band etc....of course, you still would need an external box like the Beachtek or similar to us an XLR input where to take a (balanced) feed off of a sound desk...which otherwise would be so hot that it would be very over-modulated and distorted....
Len
Len Imbery is offline   Reply With Quote
Old January 15th, 2006, 01:59 PM   #5
powered mics
Thanks all,
I believe the problem is mic gain. The mics I am using do not have a power source. Soooo, I need a MA-300 or some such.
I purchased Visual Communicator and was trying to use the included lapel mic straight into the GL2.
Thanks again,
Old January 15th, 2006, 05:40 PM   #6
What kind of mic is it? Is there a brand name? Many mics sold for sound cards are powered by the card.
Old January 15th, 2006, 08:12 PM   #7
mic types
Thanks Don,
I plugged the mic into my sound card and it works great, just like Visual Communicator said.
I was stumped when the mic would not work going directly into my GL2. All solved now.
Glen
Old January 16th, 2006, 04:53 AM   #8
As I recall, the MA300 provides about 6 dB of gain, and it is also 600 ohm input impedance. It might not provide a significant improvement with the sound card mic.
Old January 16th, 2006, 08:23 AM   #9
Fred Retread
Originally Posted by Glen Tibbits
...The mics I am using do not have a power source. Soooo, I need a MA-300 or some such....
The MA-300 does not supply any power. As a side note, it also lacks many HUGE features that are included in the equally priced Beachtek DXA-4 (beachtek.com). MA300 owners kick themselves when they see the Beachtek.
Incidentally, neither the DM-50 nor the internal mic will work with the MA300 (or any other XLR adapter).
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply With Quote
Old January 16th, 2006, 02:31 PM   #10
mic boxes
....Also have a look at the one's made by Studio 1(XLR-Pro)....much like Beachtek and you can mix and match mics and input sources for left and right etc.
Len
Old January 16th, 2006, 05:52 PM   #11
I have heard that Sign Video was the manufacturer of the original Studio One line. They also offer XLR adapters.
Don Palomaki is offline   Reply
