Shoulder Support at DVinfo.net
Old February 4th, 2006, 09:28 AM   #1
Shoulder Support
What would be the best shoulder support for the GL2? Any tips where to buy it in Holland?
Thnx
Mischa Hondius
Mischa Hondius is offline   Reply With Quote
Old February 7th, 2006, 03:09 AM   #2
Anybody?
Mischa
Old February 7th, 2006, 07:11 PM   #3
Check out the DV Rig Pro
I have one, they are great
Michael DeMattia is offline   Reply With Quote
Old February 7th, 2006, 07:16 PM   #4
This thread from the FX1 forum might be of interest: http://www.dvinfo.net/conf/showthread.php?t=40217
Also see the following, which is the same support discussed above but used with a GL2:
http://www.dvinfo.net/conf/showthread.php?t=59087
http://www.famousdavis.net/images/gl2b.jpg
Old February 8th, 2006, 01:36 AM   #5
Old Boot
Dv Rig Pro here too.
http://dvtec.tv/id27.html
It is NOT a shoulder mount, but uses the shoulder to support the rig which has an articulated joint allowing the camera to be adjusted to many more positions than just a "fixed" shoulder mount. The DV Rig Pro allows for "other" bits of kit to be bolted on. I have a 5" monitor bolted on one of the support handles.
I've videoed all day on a busy BUSY community event and I was so relaxed I could have done the evening too - if required.
Think beyond "just" a shoulder mount and there is this solution.
Here is a quick search I just did.
http://www.schweitzerimport.nl/
I don't know IF they still stock it - up to you, but I bet PECs of London will point you in the right direction.
Grazie
Old February 8th, 2006, 10:35 AM   #6
ok thanks guys!
Mischa
