XM2 random greenish tint at DVinfo.net
Old May 3rd, 2006, 08:18 AM   #1
I bought a brand new Xm2 a couple of months ago and I haven't had a problem with it until recently.
When using frame mode I've sometimes noticed a random, greenish tinge to the footage. Itīs not static, it comes and goes and itīs pretty noticable. It seems to appear when camera has been running for a while.
Has anyone experienced anything like this?
I had the camera set to manual mode, INCLUDING white balance, so it can't be a WB related issue.
It seemed to go away when I switched to normal mode ( instead of frame mode ), but I have to recheck that to be 100% sure. ( Even though it would make sense .. perhaps some kind of a bug in the green-pixel-shift-faux-progressiv-thingy? )
I managed to record the tinge last night, so if necessay I can post a short clip of it.
Any help appriciated!
Martin Lindstedt is offline   Reply With Quote
Old May 3rd, 2006, 12:20 PM   #2
Old Boot
Hmmm . .not in Normal mode eh?
Have you a preset engaged when in Manual/Frame mode?
Grazie
Old May 3rd, 2006, 03:12 PM   #3
Hey Grazie!
"Have you a preset engaged when in Manual/Frame mode?"
Yes, I have the custom preset turned on. Iīve just pulled the sharpness down alittle. You think it might be the problem?
Old May 3rd, 2006, 05:11 PM   #4
Old Boot
Hiyah . . You got anything wandering towards the GREEN within that preset?
You are manually white balancing? If so against what? What "white" are you using? I know I can get some extraordinary effects using different coloured boards. Also I can get a nasty yellowy/green tinge with certain lighting too!! What environment gets you this green tinge? Outside and inside? Have you used the WB templates?
Grazie
Old May 3rd, 2006, 05:21 PM   #5
Images: 1
It can happen if you are shooting under flourescent lighting using certain shutter speeds. It's the difference in phasing between frequency of the light ballast verses shutter speed. If taping under FL lights, set your shutter speed to the power line frequency which would be 1/50th for PAL. This eliminates the slow phase drift. Although you see it as green tinge, it's likely a change in the light levels which will affect color saturation due to the aforementioned effect.
BTW, this is the reason why flourescent lighting units for video work have special high frequency ballasts so as to eliminate that shifting.
-gb-
Old May 4th, 2006, 03:41 AM   #6
Grazie!
No, the preset is flat, except for sharpness. I used the indoor WB template. The problem is not the green tinge itself but the fact that the green spectrum in the camera seems to fluctuate.
I have put a short clip here:
http://martin.cmplete.com/greenblink.wmv
Do you guys see it? Sorry for the shaky footage.
Greg!
I actually have a fluorescent lamp next to me, and yes, it was on when I saw the effect.
I tried without it, but no, the problem remains.
Any ideas?
Old May 4th, 2006, 04:43 AM   #7
Old Boot
My first thoughts were, get some light on the subject! As were my next thoughts.
For my money, the camera is truly struggling to do anything. I even had to put your clip into Vegas, bump the GAIN just to see exactly what I was looking at.
When you shot this, just what was your exposure scale reading?
I think what you are observing is very low lighting cast by the floro you say. I think Greg's comments are spot on. Plus, give your poor camera some lighting to play with? It is only a 1/4 CCD - give it a chance! If it isn't any of these then I really don't know what is happening.
G
Old May 4th, 2006, 05:19 AM   #8
hehe, yeah, it was heavily underexposed and out of focus , i know. I was fooling around with the shutter speed, to see if it had any impact on it. Sorry bout that ..
Have a look at this clip.
http://martin.cmplete.com/greenblink2.avi
In this scene I am shooting only in sunlight thru the window. Watch the hand and the shirt a couple of times. Itīs subtle, but the green blink is there.
You're gonna have to tell me if I am being too picky about this, I just feel that a camera of this caliber shouldnīt be doing this. If it turns out that this is a normal behaviour for all XM2 out there, it would be a big relief for me, knowing that I donīt have a faulty camera.
It seems like itīs easier to replicate the problem with my larger nobrand battery. So I measured the voltage on it.
8,4 V.
Thatīs too much, the camera only needs 7,4. The orginal Canon battery was dead on.
So it could be my battery feeding too much voltage to the camera making it go crazy after a while. What do you guys think ?
Old May 4th, 2006, 06:49 AM   #9
Images: 1
8,4 V.
That could be a problem. It's not worth damaging your camera over a nobrand battery. The Canon actually runs on 7.2 volts so I would not use that battery. Try running the camera off of AC mains and see what happens. That should give you a stable unchanging reference to evaluate the issue with.
-gb-
Greg Boston is offline   Reply
