Non-Canon flash unit at DVinfo.net
Old February 13th, 2003, 12:43 PM   #1
Hi there,
I have an ten year old PHILIPS flash unit and no camera to use it for. So I looked at the flash unit, looked to my XM2, looked back to the flash unit and though "hey, let's give it a try"
But: could it do any damage to the XM2 or the flash unit? Does it have to be a Canon flash which is really expensive? It fits mechanically, but does it fit electronically also?
Don't wanna push the photo button before you tell me to do so <lol>. This acessory shoe is a mystery to me and any explanations are very welcome.
Thanks in advance,
Chris
Chris Fangio is offline   Reply With Quote
Old February 13th, 2003, 10:57 PM   #2
I tried using my 10+ year old SunPak flash in my GL2 (I just tried it, didn't worry 'bout harming the cam...I guess I should have) with no success whatsoever. I don't think it will harm your cam at all, but I doubt it will work. I think Canon rigged it so you HAVE to buy one of their nice, expensive Speedlites. So if you are concerned about harming your cam, just don't try it because I can just about guarantee it wont work. Good luck with whatever you decide!
Scott Silverman
Shining Star Digital Video Productions
Bay Area, CA
Scott Silverman is offline   Reply With Quote
Old February 14th, 2003, 05:55 AM   #3
Probably needs to be a flash that is fully Canon Speedlite compatible.. Not sure if there is such a beast. Check the photo shops for this. Maybe Subpak, Vivitar, or Metz offer one?
Old February 15th, 2003, 01:02 AM   #4
The only non-canon flashes that will work with the XL and I suppose the GL/XMs are third party flashes that are EOS dedicated. I have a StarBlitz DFC 300 that is EOS dedicated and worked with my XL1. If your Phillips flash is EOS dedicated then it should work, if not then I wouldn't bother. You won't do any damage to either, they just won't communicate.
Adrian Douglas is offline   Reply With Quote
Old February 15th, 2003, 02:02 AM   #5
Thanks everyone for your comments. So I'll have to go for an EOS-compatible unit and give it a try. Perhaps I'll find one which is cheaper than an original Canon flash.
Chris
