60I for GL2? at DVinfo.net
Old June 28th, 2006, 06:54 PM   #1
60I for GL2?
Just got my GL2, love it so far. I can easily set it to Frame Mode which is 30P. How do I set it to 60I?
Is that default if your not in 30P?
Steve Maisch is offline   Reply With Quote
Old June 28th, 2006, 07:22 PM   #2
Yes, if frame mode is off, you're shooting 60i. Frame mode is not 30p, but a digital simulation thereof.
-->jarrod whaley.
www.oakstreetfilms.com
Jarrod Whaley is offline   Reply With Quote
Old June 29th, 2006, 03:40 AM   #3
oops double post.
Old June 29th, 2006, 03:43 AM   #4
So if your looking for a film "type" look (I know, I know), would it be best to shoot in frame mode and render it as 24P/16:9 in Premiere Pro, or shoot 60I then render it that way?
I have heard it suggested both ways.
Old July 12th, 2006, 11:17 AM   #5
Well, you can't really just "render" it to 24p in Premiere. You have to use a program to deinterlace the video and convert it to 24p and then you can edit in premiere at 24p. If you want to do this, you should film in 60i because converting 30p to 24p doesn't work very well.
Your best bet is Magic Bullet but it is very expensive.
Rami Ismail is offline   Reply With Quote
Old July 12th, 2006, 03:02 PM   #6
if you go to the first menu on the gl2 it gives you the option between frame and normal, switch to normal and use magic bullet or the like to create 24p. i cant remember if the exact order of how to do things.
(Wishes to be more informative and helpful than a nuisance)
Tim Johnson is offline   Reply
