Missing bottom plate screws from GL2 at DVinfo.net
Old April 4th, 2007, 01:31 AM   #1
I just found out that I am missing 4 screws from the bottom plate of my GL2. Has anyone replaced these and at what price and source?
David Yuen is offline   Reply With Quote
Old April 4th, 2007, 05:20 AM   #2
I lost mine while working with out knowing it while the tripod was on it. went to my local eyeglass center and asked to see old screws from glasses. I actually found some. It was a miracle. however if you have an old junk camera around the screws are almost identical. I foundt his out after I found the glasses screws but needed one more!
I put a dab of JB weld in the plate before I screwed it togerther. It is a two part welding epoxy that secured the plate. No more problems.
Good luck
Bradley D Barber is offline   Reply With Quote
Old April 4th, 2007, 10:12 AM   #3
Great idea
I don't have the old junk camera but there are plenty of eyeglass centers around. Thanks for the tip. I'm not sure I want to make the attachment permanent with J & B Weld though.
Old April 8th, 2007, 06:08 AM   #4
THe JB weld stays a tad flexable. It is able to be removed later with force if it were neccessary. I thougth using like a thread lock gel or something would be too much for the tiny screws.
