built in mic at DVinfo.net
Old April 28th, 2003, 09:35 PM   #1
built in mic
Is there any way to turn off your standard mic on the gl2. I got a shotgun mic to fit in the accessory shoe and want to turn the stock mic off. Is there any way to do this?
Tim McGreggor is offline   Reply With Quote
Old April 28th, 2003, 09:42 PM   #2
High School Student
To my knowledge of the GL2, once you plug it in, then it automatically turns it off...
Alex Knappenberger is offline   Reply With Quote
Old April 28th, 2003, 09:59 PM   #3
Retired DV Info Net Almunus
Alex is correct. Just plug the external mic into the Mic hole.
Old April 29th, 2003, 06:39 PM   #4
No this goes into the accosery shoe on the top
Old April 29th, 2003, 06:43 PM   #5
Tim,
Regardless of where you mount the mic, as soon as you insert a plug in the mic in jack on the side of the camera, the cameras built in mic is electrically disconnected.
Rob Wilson is offline   Reply With Quote
Old April 29th, 2003, 07:10 PM   #6
No no no there is no plugin, It transmits all the sound from the shoe into the camera. There is nothing pluged into the mic spot. it's the MD 50
Old April 29th, 2003, 07:25 PM   #7
Tim,
Sorry bout that, didn't understand which mic you were using. On page 74 of the user manual, it appears that if you select "shotgun" on the DM 50, it would only record audio picked up by the DM 50. The other two "stereo" modes I'm guessing would mix the DM 50 with the on camera mic. Couldn't find a DM 50 manual so can't tell for sure.
Old April 29th, 2003, 07:31 PM   #8
AH haha Thanks! your the man! I owne the manuel and I coulden't figure that out. Thanks so much!
