-   Canon GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/)
-   -   35mm adapters with GL2? (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/95619-35mm-adapters-gl2.html)
Bryce Olejniczak June 2nd, 2007 11:52 AM
What is the best 35mm adapter to use with the GL2? Does anybody have any experiance with these adapters or know where I can find some sample footage? And whats with the letus website, they arn't taking orders at this time?
Mike Oveson June 8th, 2007 03:42 PM
I shot a bridal video with a homemade 35mm adapter on a GL-2. It's a big file, but it gives you an idea. It can be found here: www.ov35.com
Graham Bernard June 8th, 2007 10:16 PM
Mike? Do you want to fill in some more detail in the construction and operation of that beast? I'm very interested in just exactly what you connected together?
Best regards
Grazie
Bryce Olejniczak June 9th, 2007 09:34 AM
Yea, that looks good...
I started assembling my own 35mm adapter, it's done, besides that I'm having a hard time finding a macro lens to focus on the ground glass. So I haven't been able to even test it yet with my camera. What focusing lens did you use for your adapter?
Ben Winter June 9th, 2007 12:49 PM
On the website in my signature the "One Headlight" video was shot on a GL2 with a homemade 35mm adapter. It was a great camera, but I've since upgraded to an FX1.
Bryce Olejniczak June 9th, 2007 10:55 PM
Nice, that looked awesome... What did you build it out of, or, what did you use for your focusing lens?
Mike Oveson June 12th, 2007 09:13 AM
Best regards
Grazie
Sure thing. I used some macro extension tubes (rather cheap, I think about $10 each) as the main body of the tube. These were nice because they had the proper diameter and they also had Nikon f-mount at the end of one of the tubes.
After I had determined the proper length I would need (had to use two tubes to accommodate the optical elements) I mounted an achromat at the end closest to the camcorder lens. Then I placed a Nikon D screen in between two UV filters (to help eliminate dust on the screen itself) and mounted that at the proper distance from the f-mount. That's about it. If you'd like some more details I can show you where I got my components. Total cost (without any 35mm lenses) was about $120 or $150, somewhere in there.
I would also like to point out that Ben has quite a bit more experience in this than I do, so he is an incredible resource to tap as well. I'll help where I can, but there are others that know far more than I do.
