| Canon VIXIA HF and HG Series (AVCHD) All about the HF S10 / HF20 / HG20 and similar models. |
HF11 Capture in FCP
Hello,
i have got a nEw HF11, I have spent the last 5 hrs tring to find a post on how to capture the footage into FCP, Tried stream clip no good, i get file open error:unrecognized file type. So can some one tell me how to capture into FCP, I realy just want a quick and easy way to get my video into FCP. The only conection is USB ? and when i look in Capture setting all they say is Firewire ? I have the latest FCP on my Mac Pro.
Rob. www.rpbproductions.com robert@rpbproductions.com HD101/G5 Mac/4gig Ram/1TB HDD/30" Cinema Display/FCP. |
Okay, I am not a FCP or Mac user, but you shouldn't be capturing per se. You are simply transferring the files from the flash drive to your hard drive and working them into your editing program. It should basically be drag and drop, and the flash drive on the camera will show up as a drive. Some editors, will require some type of rewrap or transcoding from that file format, which I believe is basically mpg4.
Chris J. Barcellos |
#3 | |
I have an HF10 and I just use the log and capture in Final Cut Express
It takes a minute for the program to have the various clips appear so depending on how much you have recorded you may need to wait a bit. Then I just select the clips I want and import than. I am a novice so I might not be using the correct terms. Mike Quote:
Chris, yes, capture/drag and drop i under stand, it has MTS files on the card and FCP will not support them, yes a wrapper would be good,
Mike can you tell me your work flow, thanks rob.
#5 |
I do it one of two ways. I will be basic, because that's all I know.
Typical: Start iMovie Plug in camera Turn on camera Turn to play movie mode Camera asks on camera screen if I want printer or PC mode. Select PC mode iMovie says its generating thumbnails. iMovie asks if I want to import. I select all and import... Then I can either edit it iMovie or export XML for Final Cut. Other method: Plug in camera Turn on camera Turn to play movie mode Camera asks on camera screen if I want printer or PC mode. Select PC mode Open Final Cut Select under file - log and transfer Wait a few minutes Clips on left View on right Select clips - typically I select them all Capture Hope this helps. Sorry if this is basic, but I am a still shooter so the video is new to me. Mainly using it for family stuff and small web clips for promo. Thanks Mike |
#6 |
Hi Mike,
what folder do u import from ? when i open log and transfer nothing happens
#7 |
I click on the main folder in the canon drive that has mounted to my desktop.
It takes a few minutes for the log and transfer to read through the folders and assemble the clips. Mike |
#8 |
Thanks anyway,
Nothing happens. MMM?
#9 |
Its my understanding that AVCHD requires a mac with an Intel processor...I've been told the earlier processor simply won't work with this format. It could be this is what thwarts you.
Hope I am wrong... Michael |
#10 |
Sorry for the confusion...I read in your signature equipment list "G5", but you say in the first post you have a Mac Pro which is an Intel Mac, right? If so, the architecture isn't the problem.
#11 |
yes, i have a mac pro, everything is up to date, i have no idea why it will not work :-(
#12 |
What version of FCP?
Intel Mac Latest version FCP or FCE camera FW to mac FW camera placed in play back mode and PC selected for transfer "Log and transfer" All files should appear in new window for viewing. BTW, large files can, and will take much time to transfer...lots and lots of time on the mac book pro. Another program VoltaicHD at shedworx.com can convert AVCHD files to AIC format for usage in FCP...trial download available...and they are located down under. |
#13 | |
This is a bit confusing because Iīd like to have some sort of response. Anyway, you might try selecting the avchd folder in log and transfer; then taking a coffee break even though nothing seem to be happening. When you come back you just might have the clips, thatīs what happened to me. Strange...
All the things I use should probably be listed here |
