| Canon VIXIA HF and HG Series (AVCHD) All about the HF S10 / HF20 / HG20 and similar models. |
#46 |
how do these new cams compare tot he HG21 I just bought 3 weeks ago?
#47 | |
Well, in addition to the aforementioned search functionality the primary use for this is autofocus - the camera will autofocus on faces rather than the background, and it sounds like you can choose a face to track with autofocus. If this actually works reliably I might actually have a use for autofocus!
I'm really excited about the hfs100 - I'm seriously thinking it may replace my XHA1 for situations where the 5D doesn't work out. I'm looking forward to Scarlet but I was really disappointed that they didn't deliver what they'd originally promised - a 'professional pocket camera'. The HFs100 is getting close, and should fit into a single lens pocket in my camera bag. |
#48 |
Class 4 cards acceptable?
So, would Class 4 SDHC cards be more than sufficient for this cam?
ian |
#49 | |
Also, if the camcorders get any smaller, the HoodLoupe will start to dwarf the camcorder. |
#50 |
#51 |
I've noticed street prices with Canon are often pretty flexible once supply hits, and if I had to guess, those prices may turn out to be on the high side... what with the economy.
#52 |
These cameras look to be coming out on Amazon about a month after they are officially released in February by Canon. March 15, 2009 to be exact. They are probably going to be much cheaper on Amazon then anywhere else.
This looks like a really nice upgrade to the HF100, whereas the HF11/HG20 didn't really add much except for 24MBPS recording. Last edited by Logan Trussell; January 8th, 2009 at 07:46 AM. |
#53 |
Chris can you confirm how the native 24p mode will work on the HV40? Is it the same 24F or something new?
#54 |
That's an actual Hoodman product; just saw it at their booth at macworld today. Said it would be available soon and that they're working on something similar for the DSLRs as well. I actually picked up a Hoodloupe after trying it with the 5D - even though I've gotten used to not using a viewfinder, something about using the Hoodloupe with the 5d makes it feel more like shooting with a video camera!
#55 | |
I think that which ever way you look at it, this new HFS10 is MIGHTY NICE INDEED. Check out the "product description" at amazon, it reads like an encyclopedia of fantastic features, one feature after the next they just keep coming. I knew the HG series prices were dropping, I wasn't "in the know" enough to realize WHEN the new stuff was coming out! On top of that, portability is a concern for me, and with the new flagship HS though it's lense barrel looks huge, the camera itself is SMALLER than the HG21! (10mm thinner, 8mm less height). Last edited by Rob Kral; January 9th, 2009 at 03:00 PM. |
#56 |
I don't know if this has been answered completely or not. Can the custom control manually control the zoom, focus, aperture, and shutter?
It appears that it can, but I was wondering if anybody could confirm this? If so this camera is going to be pretty sweet. |
#57 |
Played with an HFS100 at macworld for a little bit yesterday... the new menu system is much better than the old one in my opinion. However, it still doesn't appear to have true full manual control. You've got aperture and shutter priority modes, but no way to control both independently at the same time. I suspect the workaround is to choose one, i.e. shutter in shutter priority mode, then use the manual exposure control to adjust the other - but it doesn't give you the explicit values this way.
Unfortunately cinema mode disables the gain limit controls... couldn't tell if it respected your last setting or not. The custom control can only be set to one function at a time - the button toggles between auto/manual and then the dial sets the manual level. It doesn't look like you can set it for zoom, shutter or aperture - only 'exposure', focus, audio, and auto gain limit. The gain control appears to just limit the maximum gain, so presumably with it at 0db the exposure control would only affect the one remaining property (aperture in shutter priority and vice versa). I picked up a Hoodloupe at the show but didn't get a chance to get back and try it on the canons - however the layout of all the controls on the lcd frame will likely make the setup Chris posted above impractical as the loupe and connecting wrap would essentially block access to nearly all controls on the camera. The loupe is normally meant to be worn around the neck rather than mounted on the camera anyway and this will probably be the best way to use it. |
#58 | ||
CH Search DV Info Net for quick answers | The best in the business: DV Info Net Sponsors | ...Tuesday is Soylent Green Day! |
#59 |
How will these new cameras perform in low-light situations that is the 25K dollar question. The new HF20/200 seem to have a smaller sensor than current HF10/100 and HG2x series. Will this hinder the camera's image quality and fidelity or will DVIII advancements in AutoExposure compensate for the smaller CCD?
#60 | |
I just think it's funny how things go with Canon - I also played with a G10 at the show. It has big, clicky, stacked DIALS for ISO, AE mode and exposure compensation. It was one of the best things I've seen from Canon. It was almost like using a real camera. I wish my mkII had those. Imagine a small video camera with a couple of dials like that - they could cover white balance, shutter speed, gain and aperture and then just need a ring or wheel for focus... I know, I know, it's a crazy idea. |
