the hsf10 or hsf100? at DVinfo.net
Old October 20th, 2009, 05:04 PM   #1
Was thinking about going with the hsf100 but it only using cards makes me leery. The reason being a friend of mine has a hd cam using cards. A older one,he shot a scene and the card failed. Now knowing this friend he probably used the bargain card. Dont know if that makes a difference? and if I decided on the hsf10 is the 11 a that big of a change? your thoughts thanks
Anthony Auci is offline   Reply With Quote
Old October 21st, 2009, 02:55 AM   #2
I use the HF S100 and have had no trouble with cards. I only use Class 6 and record at the highest bitrate.
I can see no advatage in even considering changing to the HF S11 - there's not enough difference to warrant it...
Old October 21st, 2009, 10:53 AM   #3
Ditto. I chose the HF S100 over the HF S10 because a) it was cheaper and b) the internal memory is more difficult to access than a card, since the camera has to be connected to a computer.
Like Robin, I only ever record at 24MB/s and haven't had a problem yet. I only use 16GB class 6 cards of reputable origin; Bytestor, Transcend and SanDisk Extreme.
Stuart Robinson is offline   Reply With Quote
Old October 21st, 2009, 06:08 PM   #4
Add one more vote for HF-S100 from me. 24MB/sec recording works great and that bit rate plays back on my PS3 with no issues. Which was a surprise. However using a mini-HDMI connector directly to TV for viewing is wonderful as well. I'm very pleased with the camera so far.
David M. Spell is offline   Reply With Quote
Old October 21st, 2009, 07:35 PM   #5
thanks guy I ordered the hf s100 today:)
Old October 23rd, 2009, 05:25 PM   #6
Just one thing and I hope you already know this - but you'll need a powerful computer to deal with AVCHD. My PC workflow is:
record to cards
use $9 card reader to offload files
transcode files with Cineform NeoHD
edit in Premiere Pro
or edit in Avid (but that's an additional transcoding step)
output to MP4 and view on PS3 or upload
Eventually I'll be burning to Blu-Ray but no burner yet.
Old October 24th, 2009, 11:59 PM   #7
I have the HFS-10, and am generally happy with it, save for the somewhat awkward interface and menu. Between the HFS-10 and HFS-100, I opted for the '10 as I was going to China and thought the built-in hard drive would possibly give me a litle more flexibility. It may have, but....I also have an HMC150 that I use to earn a living with now, and have never missed its not having a built-in hard drive. So there really needs to be something more than the built in drive to justify the price differential, in my mind anyways.
Correct me if I am wrong, but doesn't the HFs-11 give you an option to attach a Lanc control? I thought you could add an accessory device that would alow use of Lanc control devices. Depending on what you shoot, that may be significant.
Steve Wolla is offline   Reply With Quote
Old October 25th, 2009, 12:15 AM   #8
That's correct, but there are also suggestions that it'll work on the HF-S10/100 too, although I haven't seen any first hand reports yet.
Old October 25th, 2009, 04:56 AM   #9
I understand that it will work with the HF S10/100.
Anyway, I've got one on order from B&H Video in New York, so when it arrives next week, I'll be in position to confirm!
If not, watch this space or e-Bay!!!
Old October 25th, 2009, 12:44 PM   #10
If by "it" you are referring to the module that allows Lanc connection to the HFS-11, the answer I got from Canon at Duigital Expo was no, it will not work on HFS-10, 100.
Old October 26th, 2009, 07:11 PM   #11
The LANC adapter will work on several newer Canon models with some possible minor issues...
Xian Messerschmidt is offline   Reply With Quote
Old October 27th, 2009, 07:21 AM   #12
The LANC controller has just arrived - and it's working fine with my HF S100.
Zoom, on/off, - and even more importantly, focus!!!
That last function alone is worth the money for me. It'll be much easier to manually focus from the pan bar.
I haven't tried it with an external mic yet, so fingers crossed that there aren't any audio issues. I'll get back later with more results.
Old October 27th, 2009, 07:33 AM   #13
Are you using the ZR-2000, or....?
Kevin Bjorke is offline   Reply With Quote
Old October 27th, 2009, 08:21 AM   #14
Yes, but I also use the Manfrotto 523Pro normally and that's fine as well...
Old October 27th, 2009, 11:45 AM   #15
Oooo... how fast is the focusing Robin? Is it possible to do focus pulls, or is it still a case of twiddling until your finger drops off?
