Problem with HV20 Capture - Help please?? at DVinfo.net
Old April 25th, 2008, 12:26 PM   #1
I'm having trouble with my HV20 for HDV capture. I've used it successfully before but now I'm starting to think there's a problem with the cam. I'm using Vegas 8 and I can capture the tape just fine with my A1, with the same cable, into the same computer. Here's my HV20 settings:
Play / Out Setup1:
Playback STD = HDV
TV Type = Wide TV
Play / Out Setup2:
Comp. Out = 1080i
DV Output = HDV/DV
I have an HDV tape in the cam. I made these settings with the firewire disconnected and THEN connected the cam.
Any ideas?
Jeff
Jeff Bradt is offline   Reply
