HV10 comparision standard / Raynox HD-5050PRO lens - Page 4 at DVinfo.net
Old May 28th, 2007, 01:20 AM   #46
You don't need to shoot a building to check out the barrel distortion - your TV will do perfectly. See:
http://www.fortvir.net/gallery/v/tom...test+.jpg.html
This thread might interest you you wide-angle freaks:
http://www.dvinfo.net/conf/showthrea...t=80666&page=4
tom.
Old November 15th, 2007, 11:21 AM   #47
So, in conclusion:
If you fit a Raynox HD-5050 to a Sony HC7 without the 37mm-to-37mm adapter, does the back of the HD-5050 touch the front of the HC7's lens? Or does it just touch the HC7's lens *cover*? Or does the HD-5050 fit perfectly on the HC7 without the 37mm-to-37mm adapter?
Jack
Jack Kelly is offline   Reply With Quote
Old November 15th, 2007, 11:43 AM   #48
Is it feasible to leave the 5050Pro WA adapter on the HV10 at all times? I'll be traveling to China in a month and I want to know if I can leave it on or do I have to go thru the hassel of mounting/unmounting constantly?
Old November 15th, 2007, 11:56 AM   #49
You can leave it on all the time Yang but then you can leave your pyjamas on all the time too. If you're shooting at 50 mm (say) then the HV20 will give better performance (less flare and distortions and greater sharpness) if you take the 5050 off. It is after all an extra 3 elements (6 surfaces) of very slightly de-centred glass.
tom.
Old November 26th, 2007, 03:17 PM   #50
Sponsor: Schneider Optics
Originally Posted by Bert Na View Post
If it's any consolation, you're not the only one who's disappointed with the image quality of the wide angle adapters on the market. I bought a Century Optics 0.65x for my HV10 thinking that its Schneider optics will yield good results but at its widest setting, it's got the same issues as other less costly units: barrel distortion, poor corner sharpness, & optical vignetting. Mechanically, it's ok: it's fairly compact, has filter threads, it fits directly on the HV10 and has zoom through capability. Canon should consider extending the wide range of the built-in lens, many of us are willing to pay a little more for the feature...
Max wide setting:
Max zoom-in setting:
Bert,
We here at Schneider have experienced a few of the HV10 cameras with the same problems you have had. The quality on your sample images is the worst I've seen by far. I would reccomend that you send the lens into our service department for a check up. On the whole, we have not had many issues compared to the number of these lenses being used on the HV10. The major issue is also related to the placement of the CCD in this camera. Canon has about a 5% variable in placement of the CCD on this camera. This means that performance of our lens varies from camera to camera.
Please send in your adapter and we will fix or replace it.
Ryan Avery
Regional Sales Representative
Schneider Optics
Ryan Avery is offline   Reply With Quote
Old November 26th, 2007, 03:52 PM   #51
Hello Ryan,
I appreciate your offer, but I've already sold my CO 0.65x adapter (at a sustantial loss), and replaced it with a Sony 0.7x adapter which I'm very happy with. As you pointed out, maybe there was some incompatibility between my camera and your product. Thanks again for the offer.
Bert Na is offline   Reply With Quote
Old November 26th, 2007, 04:02 PM   #52
Hello Ryan,
Given the timing of your last post, I don't blame you. Information is only useful at the right time. I hope you continue to try Century products in the future.
Ryan Avery
Schneider Optics
Old November 27th, 2007, 12:48 AM   #53
Hello Ryan,
Do you or anyone know which WA lens is actually better for the HV10. I'm trying to figure out which to get.
Sony VCL-DH0730
or
Raynox HD-5050
also, is it too much to see a sample of your results with the Sony Bert?
Thaddeus Sylvester is offline   Reply With Quote
Old November 27th, 2007, 02:29 AM   #54
I have the newer Sony WA adapter, VCL-HG0737C, which is marketed as being designed for HD video cameras. It's a fairly large lens compared to the Schneider Optics lens and it doesn't have filter threads, but it does deliver excellent image quality with no resolution loss at the sides and corners of the frame. Distortion is also very well controlled. Below is a comparison between the 2 lenses.
Old November 27th, 2007, 02:38 AM   #55
Thanks for the correction and pictures. That Sony image clearly looks sharper and wider at that.
Old November 27th, 2007, 02:46 AM   #56
Ryan, I know you're watching. Has Century any plans to update the Schneider Kreutznach (UW II) single element wide-angle aspherics that they produced in the 70s and 80s? I ask because I've found these are very effective on video cameras, offering half zoom-through while at the same time giving almost zero barrel distortion for a large increase in view.
The only reason I don't recommend them more often is the fact that they're uncoated optics, and this limits their use out there in the real world. Quick - get these into production before RedEye beats you.
tom.
Old November 27th, 2007, 10:46 AM   #57
tom.
At this time we have no plans to reintroduce those optics because we make our own single element attachments. See the below link for an idea of what we make for the 58mm that we will also be making for the 43mm.
http://www.schneideroptics.com/ecomm...D=1070&IID=883
An aspherical single element lens would be excellent for video but the marketability of this piece to a mass audience would likely be poorly recieved due to cost. Our attachments are already at the top end of price and arguably worth it. How much I want to spend arguing aspherical single elements and their increased cost is unlikely.
Ryan Avery
Schneider Optics
Old December 23rd, 2007, 04:46 PM   #58
Don't BUY Raynox HD 5050PRO Lens !!!!!!!!!
It is a very bad lense. If "Lee Wilson' had not written that it is a good lense, I had not bought this lense. Without the adaptor ring, at full wide it still makes vignetting, the middle of the image is clear, but close to the edge, it is very fuzzy and unclear.
http://www.dvinfo.net/conf/showthrea...t=75774&page=4
Here is my example :
http://www.dvinfo.net/conf/attachmen...1&d=1198449453
http://www.dvinfo.net/conf/attachmen...2&d=1198449453
Johann Schlossberg is offline   Reply
