New to HV30 a couple of questions..
I am new to filmaking as a whole...but i recently picked up a HV30 on Friday from Best buy for $899.00.
I have been previuosly been using my GL2, which i really like, but I travel from USA to China for work and was tired of lugging my GL2 back and forth for 15000 miles. The manual is not real clear on a couple of things... Is there a manual mode on the HV30? How do i get to it if there is? I have read page 49 and it appears there should be a manual mode with an exposure meter. Is there Zebra stripes avail with this cam? if so How do i get to them? Thanks... Dave |
Did you press the SET button (the joystick)? if so you should see the joystick guide in the viewfinder and LCD. Push the joystick UP (the UP arrow in the joystick guide will turn yellow) until you see EXP in white letters above the joystick guide. Then at the top left of the viewfinder/LCD you should see the blue bar display for manual exposure with the =/- indicator at the side. That shows you what the meter thinks of your manual adjustment. Quote:
It's under ASSIST FUNC. Quote:
http://www.usa.canon.com/consumer/co...&modelid=16206 |
Where i think i am getting confuse is I am looking for a completely manual mode where i set both the aperture and the shutter speed. I can get the in camera meter now as you explained, and I found the zebra stripes, but i can only get the exposure bar in AV or TV mode.
Is tehre a completely manual mode where i can control bot the aperture and the shutter speed? Thanks for the PDF link.. I am reviewing now! |
there is a manual-ish exposure trick to control the aperture and shutter speed and it involves a miniSD card and a cell phone!
more information about that could be found here: http://www.dvxuser.com/jason/hv20/ Or you can search for something like "hv20 cell phone trick" to find something simpler. |
I find the 'double bump' technique easier than the cellphone trick. Basically, you slide the exposure meter all the way to the left then quickly 'double bump' the joystick in the up direction. This will reset the exposure meter and allow you to choose a greater selection of stops. Search for it as there are better explanations.
Kelly can you help us with this. "double bump" isn't giving me much of anything in a search.
There're different ways people play with the EV settings to get some noise free video. Double bump is one of them. You can also cover the lens with your hand. Then lock the exposure. Then move the EV value all the way to the left. People claim they get noise free voice. But to me, it's just max out the noise gain.. then use the EV value to make the noise less visible.
The best method is the light trick or photo button trick. That really deliver a complete noise free video. |
