hv30 with beachtek dxa-2s
i have beachtek daz-2s
with hv30 want to hook up to xlr thru soundboard whwwwat settings do i use exactly on my canon hv30 did it and got hum from sound board in bars in maui thands for advise have been told to hook up to mike but not sure what sound setting to set mike on hv30 thanks michael seiler MauiHDTV |
Sounds as if you have a ground loop --- a difference in voltage between the ground of the board and the ground of the camera. Hum eliminators isolate the grounds and fix this, here is a link to one such: Buy Ebtech HE-2-XLR Hum Eliminator with XLR | Noise Gate & Suppressor | Musician's Friend
Also, iirc, that model Beechtec has mike/line level switches, you probably need line. A peculiarty of the hv20/30 --- if you plug your headphones into the av/headphone socket and it is not set in the menu as headphone, you will hear a really annoying hum and no audio. Just a thought. /Battle Vaughan/miamiherald.com video team |
You may also be hearing the hum from the HV's amplifier. As best you can, turn that down to get as clean a signal as possible.
I used a BeachTek for a while on my HV, but the noisy amp caused me to get a JuicedLink. I've since moved to dual recording, but I found the JuicedLink was a great product. Ate 9V batteries nearly every 90 minutes with one phantom feed...but that's a small price to pay for audio that sounds good! |
