HFS10 Sample clips
Has anyone seen / posted any sample clips from the new HFS10 in the original .mts format?
I am anxious to see how well this camcorder does, particularly in low light. I would especially prefer to see clips directly from the camera rather than those which have been passed through Pixella, QuickTime, or any other processing. Thanks for any links. Larry |
Mts files
Well Larry, when I loaded my SD card thru the card reader and it mounted I went inside I opened to see what kind of folders and file structure it had, since I'm new to this ACHVD format, in one of the folders I saw, a lot of mts files with numbers 00001, 00002 etc. I tried to open one of them with MPEG Streamclip app., but it did not open, I'm working on a Mac but don't have Final Cut Pro. If you can walk me to a workflow to extract these files in some workable formula I be happy to help. Can you upload these raw files thru Vimeo without alteration
Thanks Luis |
Thanks Luis for your prompt reply.
I am indeed looking for one or two short sample files in the very place you have been looking, the files numbered 0001.mts, 0002.mts, etc. These are placed in the STREAM folder during capture by the HFS10. Rapidshare.com allows a 200 MB maximum file size and seems to work ok for the few times I have used it. (Vimeo does not accept raw .mts files for download / input, and therefore would only be useful if I wanted to see files after they had been transcoded by Quicktip or other encoders.) I believe roughly 1 minute long clips should be around 200 megabytes (for the highest 24 Mbit/sec camcorder quality). I would greatly appreciate any clip or clips which would be 1 minute or less showing how the camcorder looks in low light and in good light, and preferably with some horizontal and vertical motion / panning to give the camcorder a bit of a stress test. Thanks very much again Luis, Larry |
Buba,
Your clips are really impressive, and show some clear advantages over the HF100 I have been using. The extra bit rate, better sensor, better lens, and better encoder are really beautifully combined to make visible improvements in sharpness, motion artifacts, low light noise, and overall clarity. No doubt it is time to eBay / craigslist my HF100............. This is a really nice collection of small samples. The last ones look like they may have been shot in Niagara Falls, Ontario? I have alot of AVCHD, HDV, and DSLR photography in Canada since I live just a few miles from the border. Thanks very much for putting these samples together. Yours are literally the first and only samples I have seen of the new HFS10 despite a lot of searching. Larry |
As I mentioned above in this thread, Vimeo cannot be used for showing or transferring true HD data. Nice movie clips but not for critical comparisons. Larry |
Thanks Buba for the files that helped me a lot.
But my conclusions are less enthusiast than the others. I have converted the avchd files with VoltaicHD to be able to read them in uncompressed tiff sequences and quicktime. When i use an histogram in shake to look at the colors, there is not a lot of things left. that worry me a lot. And try to decrease the contrast you will quickly see some artifacts. People are talking of sharpness, i say really pixellated lines. It is sad you have shoot the footages in interlacing, it is hard to judge the picture even if i de-interlace the pictures, all the motions are very interlaced. But my other concern is the Cmos rolling shutter artefacts, every motion have heavy skew, really heavy. and i see a lot of hardcore wobble very often. I am seriously worry about all of that Your files are using the new 24 mb/s recording ? do you have some files in 24p or 25p ? i must admit that the vimo video i have seen looks fine except the wobble, but it is internet... to put me in the context, i am a vfx professional compositor, more used to 35mm high resolution for film so i have surely too much expectations. I want to buy a camcorder to start doing my own tests. Are all my worries usual for that range of camcorders ? tape and avchd ? thanks Olivier |
hey Olivier, glad it helped:)
hf s10 is a great consumer camcorder with a very nice set of manual controls, and with the proper lighting equipment and post I think it can produce commercial quality footage, but it's still a consumer camcorder so don't expect too much, although day light picture from hf s10 is better than from FX1 (i used to own one) all samples were shot @ 24mb/s and I believe 30p, sure I'll post 24p footage, and if you have some settings in mind let me know, |
Are you sure you was in progressive mode recording ? some of the footages have an heavy interlacing for me.
I am still thinking to buy one, i will just wait a bit to see if sony will have something for this summer. I quiet like there little option to have a slow recording option, but... we can't have everything, and i know i have very high expectations because of my work :) thanks again |
I can't properly play the .mts files in my new white MacBook... Do I need a Mac Pro to play them?? MPEG Streamclip doesn't open them either... :-((
And the other would be to edit a short sequence in your NLE and render it to a high definition file format (HD 1920x1080 WMV or HD MP4) and play that in something like Windows Media Player to see what it looks like. VLC does a pretty good job of playing the .MTS files if the computer can keep up with it. Quote:
Worst cases of wobble and skew I have seen in others footage is where they have not isolated the cam from vibration. Quote:
Get one and start having fun with it. Quote:
Good Luck |
Low light looks good, except for the smearing.
