HV20 Firewire capture issue
Hello. I'm trying to capture footage from an HV20 camera. For some reason, when I connect with Firewire Vista does not see the camera. At first I thought it was the camera but I tested it on an XP computer and it found it.
I tested my external HDD with firewire on my laptop's port and it worked fine. I have this same problem with Windows 7 too. I even bought a firewire express card to capture with and even that didn't work. What's going on? |
1. HV20 has two setting to download, one DV only, the other DV and HDV, with camera autodetecting. Make sure that is set properly.
2. If you are capturing HDV, you need to be sure your capture program actually captures HDV. Also, many programs will require you to select the capture source. 3. If you are sure it is HDV, and the camera is set right, try downloading HDV Split and see if it works in detecting camera, and for capturing HDV. If you camera is not set right to capture HDV, HDVSplit will say it can't find the camera. 4. If all else fail, try a different firewire cable. |
The cable's fine as I tested it on another computer and it found it immediately.
I had a similar problem with my firewire connection, but I knew the cause -- a tripped over cable pulled my camera off a table and damaged the port.
It cost $169 to have a Canon Service Center replace it and took about 10 days (including shipping time). I'm not sure if they only replaced the port or if there was something more inside that needed to be replaced. Either way, it works like a charm now. Phil |
Vista Firewire
I have a Canon HV20 and HV40. Vista 64bit will not capture from either of my Canons. I pulled my hair out for two weeks trying to solve the capture problem.
I removed Vista 64 and installed the Vista 32bit, and I have never had a problem since. |
I really don't want to go that method as I have 8 Gigs of Ram on this laptop.
Well I put on Windows 7 32 bit. No dice.
