What type of MiniDV Tape do you guys recommend I use? And a couple more ?s.
Sorry to continue with the questions, but I'm just too excited about my Camera and just want to make sure I get the best accessories I can for it.
As I await the delivery, I was hoping you guys could help me pick out the accessories I need for my new Camera. What type of MiniDV tapes are you guys using? (I don't mind paying top dollar for the tapes.) I'm also going to get the Raynox HD5050 WideAngle lens, but what about a telephoto lens (if possible)? Anyone using one on there Hv10? And last but not least, what about the BP-315 battery...what sort of batttery life (shooting time) does it offer? Thanks for your time guys. |
I use Panasonic AY-DVM63MQ tapes in all my DV style camcorders. I like the "dry lube" process Panasonic uses. I think the most critical thing is to not mix a lot of different brands.
I had a JVC tape free with the Cam which I used and have now switched to Sony Premium (I hope thats not a problem?) TO be honest I cant tell any difference and Im not sure what if any it makes? I havent had any dropouts so far. I know Sony use "wet lube" and Im not sure what difference that makes. Well I have 20+ sony tapes now so I shouldnt need to change for a while
I bought the BP-315 too I think it nearly doubles the standard battery time. |
Has anyone tried the HDV tapes? I'm looking at the Sony tapes as they are cheaper than the Canon ones, but wondered if they are really needed / recommended or if standard miniDv tapes worked fine?
miniDV is absolutley fine - (check out my samples on other threads)
HDV tapes were just designed to limit dropouts I think. |
With the Tele converter you will need a tripod for sure for steady shot. I use the Canon recomended for this camera, no drop off in the corners or vignetting, I've seen previous reports on the Raynox HD converter does well in this Dept. also. Stick to one tape brand, HDV or reg MiniDV. Luis |
Hi,
I use both Sony HDV (DVM-63HD) & TDK DVM-60ME cassettes. Didn't see a single dropped frame in any of them. E.S. |
I use Panasonic AY-DVM60EJ tapes you can find at every CompUsa, CircuitCity, BestBuy, Ect.
also the battery if you go to BH they have a extended life 4 hour battery for the hv-10 made by impact for about 30 bucks a pop thats hafe the price of the energizers you can buy at retail stores. check out my other post with footage i shot that with the tapes i use. just dont mix brands once you pick a tape stick with it. AND don't buy the sony pack with the 2 tapes and the minidv cleaner. don't clean your heads unless you really need to. on there packaging they say to clean heads after every two tapes. don't do it! |
