HV20 questions re audio at DVinfo.net
Old April 5th, 2007, 02:10 PM   #1
I'm considering a purchase of the HV20 and I was curious if there is significant noise picked up by the on-board mic from the motor or when zooming? Is it louder than the HV10? Will an external mic pick it up?
Will most mics fit in the mount?
Will a mic with xlr adaptor be unbalanced or have added noise?
best,
elmer
Elmer Lang is offline   Reply With Quote
Old April 5th, 2007, 09:39 PM   #2
I can hear the noise picked up by the built-in mic. The only thing I can compare to is a Panasonic PV-GS250. The HV20 is louder. However, my experience with the HV20 is limited to about 20 minutes of recording so far.
Thomas Emmerich is offline   Reply With Quote
Old April 5th, 2007, 10:03 PM   #3
"Internal" mikes really suffer on small camcorders. If you want good audio you must use an 'external' mike.
JohnG
Nikon DSLR's finally a small 60P camcorder (Sanyo VPC-FH1)
John Godden is offline   Reply With Quote
Old April 5th, 2007, 10:27 PM   #4
Yes, external mic is the way to go, but I worry even that will pick up motor noise.
Old April 6th, 2007, 08:54 PM   #5
For the best results get your external mic off the cam and close to your subject. The distance from a person's mouth to a mic for the best audio is measured in inches, not feet. This is true for SD, HD and whatever else comes along.
Good luck.
Dennis
Dennis Vogel is offline   Reply With Quote
Old April 7th, 2007, 08:56 AM   #6
Anyone have any ideas on which Beachtek adapter would work best with the HV20? http://www.beachtek.com/
Peter J Alessandria is offline   Reply With Quote
Old April 7th, 2007, 09:26 AM   #7
Peter,
Harry at Beachtek said the following:
"We are working with Canon in the US find an appropriate adapter for this
model. It looks like our DXA-2s Compact Adapter will fit this camera the
best."
Harry is really helpful and responds to emails instantly! His email address is beachtek@bellnet.ca
Roland Gatto is offline   Reply With Quote
Old April 7th, 2007, 10:15 PM   #8
Originally Posted by Roland Gatto View Post
Peter,
best."
Actually got two emails from Harry today (Sat.) He recommends the DXA-2s if you don't need phantom power or
"If you require phantom power, then our DXA-6 adapter would be ideal for the HV20. The DXA-FX adapter is only designed to work with the Sony FX1 or FX7 camcorders." [from Harry's email]
(I asked about an adapter with mic preamps)
Old April 8th, 2007, 05:18 PM   #9
HV Questions re audio
I'm thinking of using my Sennheiser MKE 300 mic on the HV 20. Has anyone tried this combo? Using the MKE 300 on my Sony HVR A1U produced a lot of vibration noise etc and I wonder if it's the same with HV 20?
Thanks.
Roger Garcia is offline   Reply With Quote
Old April 8th, 2007, 05:22 PM   #10
I tried the MKE 300 on an HV20 and it was picking up motor noise and fast zooms.
Old April 8th, 2007, 05:28 PM   #11
Thanks- that's a pity. Looks like I'll have to go with a proper mount and my shotgun then : )
Old April 8th, 2007, 08:54 PM   #12
Hey Roger, if I was you I'd still try the MKE 300 since you have one and all, your experience might be different than mine! And if it was, you could post your experience.
Old April 8th, 2007, 09:26 PM   #13
Though I haven't tried it yet, this is what the Beachtech DXA-4 looks like,mounted to the HV20. See photo attached.
Chris J. Barcellos
Old April 8th, 2007, 09:36 PM   #14
Hey, Chris, lookin' good!
Will that setup limit you to handheld, maybe it's the angle, but I don't see how you could put it on a tripod? Either way, I look forward to your comments, I've been enjoying your 'Sony User Tries Canon HV20' thread each step of the way!!
best,
elmer
Old April 8th, 2007, 09:51 PM   #15
Elmer:
The adapters that are made to bolt on to the bottom of a camera, have a have the same thread underneath that is on your camera. See the picture attached. This week sometime I plan to try the rig with my Sennheiser ME66 attached. Biggest issue I see is the potential for mic, due to length, protruding to far into picture frame...
Chris J. Barcellos
