April 17th, 2007, 03:32 PM | #1 |
Is HDV pointless unless you have an HDTV?
is there no point in taping in hdv unless you have a hd-enabled monitor/screen to watch the footage on?
April 17th, 2007, 04:03 PM | #2 |
I know that people say or imply things like that, but I disagree. I don't have an HD enabled screen and I can tell you that I can definitely see the amazing clarity and resolution difference between HDV and DV footage.
April 17th, 2007, 04:05 PM | #4 |
Not really, most computer monitors today can display 1280x720 no problem... 1920 x 1080 is slightly harder to get...
April 17th, 2007, 04:05 PM | #5 | |
Hi!
If SD is all you have, you will never be able to make HDV out of it. ;-) I record and edit everything in HDV, afterwards I render it in the original size with 25 mbps for my archive for future use and to the formats I need right now, what usually is 1280 x 720 or PAL. Regards, Oliver |
April 17th, 2007, 04:14 PM | #6 |
Because of the much higher original resolution you suffer much less from imperfections on pixel level such as noise, charge bleeding, maybe fringing, but most of all color resolution decrease because of the primary color filter and YUV 4:2:0 color compression, etc. That is provided you shoot in HD and go SD in post. My guess is you will see the difference!
April 17th, 2007, 04:24 PM | #7 |
Oliver, you make a good point about being able to downgrade to SD, but not upgrade to HD.
Thanks for the responses, folks! |
April 17th, 2007, 07:11 PM | #8 |
I can't begin to explain the difference between seeing the output of an HV20 on a non-HDTV and a true HDTV. To say the difference is dramatic is an understatement. You can't begin to see the power of this tiny tool until you see its output on a nice sized HDTV.
April 17th, 2007, 09:05 PM | #9 | |
My computer monitor falls into the non-HDTV category and, as I said in my initial post here, I disagree with the assertion that there's no point in shooting HDV unless you own an HD monitor because the difference between HDV and SD images on my computer monitor are extremely obvious. |
April 17th, 2007, 09:08 PM | #10 |
That's true of course. I work at 1600x1200 on my CRT and that is more than enough to play the native 1440x1080 HDV files.
April 17th, 2007, 09:30 PM | #11 |
My video shot in HDV (Canon XH A1) edited in Prem Pro 2 and then exported at DV is definitely superior to the video shot in DV by my GL-2 and XL-1s. I am now spoiled by HD, all DV shot by any of my camcorders just seem less vivid. However, the DV product is definitely better starting at a resolution better than a studio cam and downscaled in Post gives max SD resolution vs DV at only 500 vs 700 max SD.
Bill in Ohio |
April 17th, 2007, 10:45 PM | #12 |
Ken's right. Displaying HDV on a high resolution computer monitor is far less satisfying than on a proper HDTV. Yes, you can see it in full resolution, but a larger screen HDTV with home entertainment quality deinterlacing makes HDV a stunning presentation. And if you have an HV20 with its HDMI output, even better.
April 18th, 2007, 01:41 AM | #13 | |
I run at 2048 x 1280 and my second screen at 1280 x 1024... I used to run at 1920 x 1200... but went a bit higher :) Highest my monitor can do is like 2330 x 1440 24" Widescreen CRT ;) |
April 18th, 2007, 06:08 AM | #14 | |
I am all for shooting your memories in HD even if you don't have an HDTV since that HD tape will always be ready to expose its full glory when you do buy an HDTV. And let's face it, you eventually will have an HDTV. :) |
April 18th, 2007, 07:47 AM | #15 |
Yeah... well... I have a mouse with blinky lights! So there. :)
