Canon XA20 or HF G30 settings for weddings at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old May 26th, 2015, 11:58 AM   #1
For those of you who shoot with Canon XA20 camcorders (or Canon Vixia HF G30), what are your Media settings: Movie format, Recording Mode, Frame Rate. I have the HF G30 and have been shooting AVCHD, 24MBPS, PF29.97. It was suggested that I should upgrade and shoot weddings at 1080p/24.
Output will be to Vimeo, BluRay, USB and I'm sure will still have a few DVDs for parents.
NLE is Adobe Premiere Pro CC 2014.
Thanks.
(and sorry to people in other forums that have already seen this post. I didn't find the Canon XA and VIXIA sub-forum until a couple of minutes ago.)
Valerie Draves is offline   Reply With Quote
Old May 27th, 2015, 05:53 AM   #2
Re: Canon XA20 or HF G30 settings for weddings
Run some tests. Try both modes in typical situations you encounter and determine which better meets your needs.
I usually shoot 1080i.
dpalomaki@dspalomaki.com
Old September 10th, 2015, 01:33 PM   #3
I shoot all of my weddings at 1080/24P. Given how dark most receptions are, the slight drop in frame rate form 30 to 24 allows just a bit more light into each frame which is paramount to getting the least possible noise in your images. Also, since PF29.97 is not a truly progressive format and 24P is, it seems to play more nicely with Final Cut Pro X upon import. So between those two reasons, for me it's a no-brainer to shoot 24P... however your mileage may vary! =)
Ryan Chaney is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
