Noisy sound Moving inside lense area
Hi, I have received XF300 today. When switch off camera I moved vertical & diagonal side to side I hear something noisy sound moving around inside lense area. Is that normal thing?
Re: Noisy sound Moving inside lense area
Yes that's normal. I have 5 of them at work they all do that. I assume it's because of the semi-manual lens. I was concerned too.
I am grateful for your help, Thank you.
Hi
Probably the optical image stabilizer system that rattles. It needs power to work, then it will stop rattle. Most camcorders with similar systems works the same. Regards, /Bo |
Hi Ras,
Almost the same type of noise I hear when I power up my XL2 :) As Bo mentioned, it's the IS kicking in. |
