Rode NTG-2
Has anyone used the Rode NTG-2 microphone on the XF300/305? I am thinking of getting one but read that some people where having issues with the fur on the deadcat getting into the picture on older XH A1.
Re: Rode NTG-2
Andy,
I use the Audio-Technica AT897 on my 300 (with the Rycote) with no problems - and that mic is one millimeter longer than the Rode... :-) |
Re: Rode NTG-2
Re: Rode NTG-2
Andy,
Do you mean the actual Rode deadcat? It might be an idea to try something like a Rycote Softie, they are a bit neater with hair that is a lot less "straggly" and less prone to hang in the lens. Disclaimer: I haven't tried it on the XF300! |
Re: Rode NTG-2
Re: Rode NTG-2
Re: Rode NTG-2
Some slight variation on the question. I have an NTG-1 mic on an XF100. If the mic were mounted in the provided bracket, the fur of the dead cat just barely enters the frame in the upper right. But since the bracket is for 25mm mics and the Rode is 22mm, it doesn't really fit. Rode makes a mount, Rode SM5 ($50USD at B&H) that is a shock mount and has a pole that fits into the Canon mounting bracket. This has the effect of raising the mic just enough that it doesn't enter the frame.
Click link to see the mount. http://www.bhphotovideo.com/c/product/463089-REG/Rode_SM5_SM5_Shotgun_Microphone.html Regards, |
Re: Rode NTG-2
Sorry Andy, haven't forgotten, just haven't had the time.
Have taken pics though and will upload them this weekend. |
Re: Rode NTG-2
7 Attachment(s)
Here goes.....
first pic: I have 3 microphones. Senheisser M<66 NGT2 NGT3 Rest of the pics show the NGT2 on the XF300. |
Re: Rode NTG-2
1 Attachment(s)
I got this from Rode.
Re: Rode NTG-2
3 Attachment(s)
And used it like this in the first picture.
Until someone told me a better way of using it (second and third pics). |
Re: Rode NTG-2
1 Attachment(s)
I also got this from rode as well. I don't really use it much as the wireless receiver is usually located there.
Re: Rode NTG-2
2 Attachment(s)
While I'm taking pictures......
I also got this cube thing which allows me to add three bits of equipment. I used to use this all the time until I got the shoulder mount from Olav. If you do buy it, make sure you buy spare connector bits as well as they will break if they fall on the floor. |
Re: Rode NTG-2
2 Attachment(s)
and lastly, Olavs shoulder mount.
Used it on both the XHA1 and the XF300. I've spent a lot of money on various shoulder mount systems and Olavs' one is the best one for what I do and also the cheapest. Pic shows part of the bracket that's attached to the camera. I connect the 2nd receiver there. Hope the above info helps and sorry it took so long to post up. |
Re: Rode NTG-2
Many thanks for the pictures. I will definitely get the mount thing with the mic.
Andy S |
