Flag for XF305 and best noise reduction
I'm looking for a simple way to reduce glare on the lens when shooting toward the sun. Does anyone know of a simple flag that can attach to the lens hood? I have a shotgun mic on top with a large windscreen, so a card fixed to a clamp on the end of a bendy wire that attaches to the flash shoe does not work.
Also looking for the best noise reduction software for some footage I shot where I left the gain on. Would like to save the footage if possible. |
Re: Flag for XF305 and best noise reduction
Neat Video - best noise reduction for digital video |
2nd on Neat Video - came in very handy on my 1st shoot/edit
Hi Bob,
If you set the max auto gain to 12 you will be OK if the auto gain switch is on unintentionally. Regards, Doug. |
We are showing these landscape videos on a 60 inch screen and have found that the only scenes that were truly noise-free were shot with -6db gain. Those shot with +6db are too full of noise to be useful. Even 0db had some noise.
From now on, I will only shoot with -6db of gain and use a slow shutter in dark situations. Also, we have not found Neat Video to be as useful in reducing noise as noise reduction in FCP. |
I used the Auto selection and as long as it selects an area that has minimal detail then it will remove the noise. Just for info I had 9dB gain set as max on a particular shoot and was gobsmacked when I checked it out in FCP as the dark areas showed bad noise problems. Neato did it's trick with the only downfall being a 6X render that was needed so a 10 minute clip took 60mins to render out. In hindsight it was "well worth it" as at least the clip is now useable (pretty damn good actually) so I am well pleased. Of course in future I will be monitoring my LCD very, very closely using the magnify option and black and white to check out noise more carefully (thanks to someone on this forum for this tip). |
I agree - you should play with the settings on NEAT VIDEO - should return much better results than FCP.
They have a few tutorial videos on the site that really go over all the options... |
