January 28th, 2010, 02:46 PM | #151 |
I don't know how smart the AF is, but a lot wild life has some form of camouflage which could cause problems for a system that's set up for human beings rather than animals with counter shading etc.
January 28th, 2010, 02:52 PM | #152 | |
If Canon could offer something similar to the EX1r with a better codec, they'd give Sony a run. The NXCam is really going to sew up the $5k space I think. Once you get north of that, the EX1 is the heavyweight in the room. South of that, the HMC150 is the obvious target. What baffles me is that these manufacturers seem to have all the stuff.. just not on one camera. It would take NOTHING for Sony to turn up the bitrate of the EX1r. It's offering HDV and 35Mbps XDCam. Just allow 50/100Mbps XDCam and the #1 knock against the camera just fades into oblivion.
DVX100, PMW-EX1, Canon 550D, FigRig, Dell Octocore, Avid MC4/5, MB Looks, RedCineX, Matrox MX02 mini, GTech RAID, Edirol R-4, Senn. G2 Evo, Countryman, Moles and Lowels. |
January 28th, 2010, 03:00 PM | #153 | |
January 28th, 2010, 03:02 PM | #154 |
Could be that Sony don't want to step on the toes of their higher end cameras by putting the higher bit rate into the EX1r.
January 28th, 2010, 03:06 PM | #155 |
No doubt about that whatsoever Brian.
They are shamed by people like Convergent Designs who prove it to be true. Steve |
January 28th, 2010, 03:09 PM | #156 |
Um,
Based on what Sony put in the EX1(r) it doesn't appear they care about stepping on their more expensive cams at all. Moving 1/2" sensors down the range. Moving SDI down the range, etc. What's the next model in the Sony line that does over and under cranking? Replaceable lenses on the EX3. The image shaping on the EX line is right off the $50k level cams. If anything, Sony seems to be more willing than anyone else to take features from the big boy cams and move them into the prosumer line.
January 28th, 2010, 03:25 PM | #157 |
It sure looks like the NX5U is going to be doing some stepping on the EX cams, with some of it's features (like very elegant and affordable redundant recording). Sony is competing with themselves more than any other camcorder manufacturer is.
January 28th, 2010, 03:29 PM | #158 |
Perrone, they are stopping short of the higher end cams by not putting 50 or 100 mb/s codecs in the EX - no reason at all other than marketing.
Steve |
January 28th, 2010, 03:36 PM | #159 |
If Canon's new cam offers H264 encoding at 32Mbps (or higher), along with an imaging block that can resolve 1000 lines of detail cleanly, Sony may have some incentive to offer higher bitrates with the EX cams. Right now they don't.
January 28th, 2010, 03:43 PM | #160 | |
It's the same reason that overcranking failed on the SDHC cards in the original EX1/EX3 once you got to a certain rate.
January 28th, 2010, 03:51 PM | #161 |
I just wouldn't be surprised if Sony soon introduces a format that uses high-bitrate, long-GOP H264 encoding, to replace XDCAM for the future - would really make a lot of sense.
January 28th, 2010, 04:01 PM | #162 | |
Steve |
January 28th, 2010, 04:14 PM | #163 | |
2. The Nanoflash is not using SDHC... it's using Compact Flash 3. Sony have several high bitrate codecs already... just not in the EX1(r) So of course it can be done, but there are physical limitations in the EX1 that prevent it from happening on certain media.
January 28th, 2010, 04:17 PM | #164 |
But to get to the SDI it has to go through the internal bus.
SxS can go to very high bitrates, so you could use that for quality work (as you likely would anyway) and SDHC for low bitrate stuff. It's just impossible to argue against it. Steve |
January 28th, 2010, 04:21 PM | #165 |
How much sense does it really make for Sony to stick with MPEG-2 much longer though? After a few more new CPU generations (think CPUs with a dozen or more cores that are at least twice as efficient as i7 per core), MPEG-2 just won't offer much comparative advantage for editing purposes, but does suck up significantly more bandwidth (and space). In a few short years things might flip things around a bit, since HDD speeds aren't getting faster nearly as quickly as CPU power - with the lower bandwidth of AVC (faster HDD reads and writes) providing for an overall performance advantage once CPUs can handle AVC as easy as melting butter on a hot griddle.
