January 19th, 2010, 05:00 PM | #76 | |
Avid Media Composer 3.1.3. Boris Red and Continuum Complete. Vegas 8.0c. TMPGEnc Xpress Pro 4.0 |
January 19th, 2010, 05:43 PM | #77 |
AVCHD at that bitrate might look like XDCAM during playback but certainly won't work the same through the postproduction workflow. Streamlined production is all about workflow, process, and interoperability. That's one thing that Sony has done well in this business.
software engineer |
January 20th, 2010, 03:06 PM | #78 | |
January 20th, 2010, 09:49 PM | #79 |
I would still agree with Jad, after serious grading and effects the XDCAM codec will be more robust
January 21st, 2010, 02:04 AM | #80 |
High bit rate AVCHD is more diffcult to work with in post b/c the codec is very computationally intensive, but I can think of no reason why it would be less gradeable in post.
XDCAM EX has a MUCH more established workflow that will make working with it considerably easier. But that doesn't mean it's visually superior or can be pushed more when being graded.
January 21st, 2010, 09:42 AM | #81 |
I think it depends which XDCAM codec. AVCHD and XDCAM EX are both 8bit 4:2:0, so I'm not sure there's much difference there. But XDCAM HD422 is 4:2:2 (also 8-bit, I think) so it would be better for grading.
January 21st, 2010, 10:29 AM | #82 | |
January 21st, 2010, 02:23 PM | #83 |
Even uncompressed audio is well under 10% of total bandwidth - and compressed audio, far less.
AVC, at roughly 2/3 the bandwidth of MPEG-2, can produce roughly similar quality, if the codec is efficient. AVC is still fairly young, so some modest improvements on in-camera compression efficiency are likely over the next few years, but right now it looks like codec efficiency in prosumer level AVCHD camcorders is already quite respectable. The major camcorder manufactures have had more than a couple years of experience, producing consumer AVCHD camcorders. In this industry, that's a whale of a long time really. |
January 21st, 2010, 04:44 PM | #84 |
To put numbers on the data rate,
48 KHz 16 bit PCM stereo sound requires 1.536 Mbps. The compressed MP3 sound that normally piggybacks on HDV and AVCHD uses ~376 Kbps. |
January 21st, 2010, 05:15 PM | #85 | ||
I was sceptical when I heard what was proposed, but my own subsequent experience is that what they say seems accurate - I'm noticing virtually no difference in picture quality. This is all referenced at BBC - BBC Internet Blog: The Hitchhiker's Guide to Encoding: Life, Encoders and Everything (Or a brief history of HD encoding) I'll quote just a bit of that: Quote:
(Blu-Ray is different, when the coding is done in non-real time, and two-pass becomes possible, for camcorders you obviously need a real time encoder.) So if that was the situation for real time broadcast a couple of years ago, and I don't find it credible that the AVC-HD encoder in a prosumer camera such as the HMC150 was substantially better. That is not to say the situation won't change, so my feeling is that future improvements will be more than modest, but AVC-HD in cameras whose design is a year or two old is not that much better than MPEG2. |
January 21st, 2010, 08:10 PM | #86 |
Very interesting. This stuff is complex, but it is important to stay on top of it all.
January 24th, 2010, 07:49 PM | #87 |
Go Cycle
Hang in there.......you may be very surprised by the end of 2010. That's all I can say.
Lou Bruno |
January 25th, 2010, 12:30 AM | #88 |
That sounds interesting!
January 25th, 2010, 02:53 PM | #89 |
It would be uncharacteristic for Canon to introduce a new model, and then top it in the same year. If there is something else coming out, it probably is different enough not to threaten sales on this prototype.
January 25th, 2010, 04:39 PM | #90 |
Thinking about this and reading what everyone has posted, if I were Canon I'd continue w/ the 1/3" for as long as I could get away with... maybe move up to 1/2" or at the most 2/3" in another pro video line.
And I'd let the DSLR continue to merge w/ digital cinema camera needs. But I would not create a specifically designed "Red killer" camera, as I don't want to get into a fight over such a small market.
