Alternative for a firewire port?
Hi gang. I checked the manual before posting here, but I couldn't find an answer.
I see the 300/305 doesn't have a firewire port. This makes sense since I guess they don't actually send a DV or HDV signal. But is there any other way to easily send a signal for live streaming applications? One important thing I do with my A1 right now is live streaming events for work. I connect the A1 to my laptop via firewire and stream live on ustream. I'm considering getting a 305 for work, but would I have any means of doing a live streaming event without a firewire port? |
HDMI, component, SDI.
Thanks, Chris.
But damn, none of those options are especially convenient for field work, are they? All I needed before was my XHA1, firewire cable, and a middle of the road laptop. Are there any simply PCMI card options for HDMI, component, or SDI? |
Bob,
Check out the link below. The Matrox can be used in studio or on location. I'm thinking this may be my solution in more ways than one: http://www.dvinfo.net/forum/final-cu...-shooting.html Jonathan |
Thanks, Jonathan, but I don't know if that will work. Any idea if the The Matrox will output a DV/HDV signal to the laptop?
I think the Ustream software will only work with DV, HDV or USB (webcam) video. |
I have the same need for live streaming.
Assuming there's a clean analog output, you could maybe use an a/d converter, like the Grass Valley ADVC-55 Analog to Digital Media Converter - which is bus powered over a six pin firewire cable. It's reasonably cheap. At least I hope that would work, because firewire output from a cam is getting to be a thing of the past. |
I'm thinking the 300/305 may not be for me. It seems the removal of certain legacy technologies seems a wee bit short-sighted to me. Certainly people would use this camera to live stream without expensive and potentially bulky extras? Certainly people with this camera would need to quickly and easily deliver SD video from time to time?
Ten or twelve years ago I had a new XL1S, I walked my video to the live van and asked if he wanted my fire wire cable. He replied "huh". I talked with the same videographer yesterday about camera specs. Cameras in my price range finally have SDI. When I told him that he said "it's ok, but firewire is better, it goes right into my system without any work !! go figure.
I know, Chris. I'm just a bit disappointed. I'm in the position to buy the latest and greatest gear, and I was ready to play with a new toy :)
Bob,
A comment from a colleague made me dig a little deeper - both these cameras can output SD via component - does that help? Nick. |
