Log and Transfer at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XF Series HD Camcorders
Canon XF305, XF205 and XF105 (with SDI), Canon XF300, XF200 and XF100 (without SDI).
Old July 9th, 2010, 10:44 AM   #1
Log and Transfer
Hmmmm ... FCP's log and transfer -- can't review clips unlike AVCHD files where you can review clips and even set in an out points before ingesting ....
Can anyone help please? What do I need to do to enable me to review the Canon files in L&T window?
Thanks.
Shuf
www.malaysiakini.tv
Shufiyan Shukur is offline   Reply With Quote
Old July 9th, 2010, 02:04 PM   #2
Should just work, I can preview & set in/out in L&T with FCP 7 and the plugin.
The only weakness of the system is that the folder structure has to be kept intact, either on the card or, if you copy the card, keep the directory intact by copying the whole CONTENTS folder to disk.
On the mac, if you loose the structure, there is a big problem. Prem CS5 may be able to see the files - anyone?
Nick
File Type: pdf Screen shot 2010-07-09 at 20.59.44.PDF (477.2 KB, 255 views)
Nick Wilcox-Brown
Nick Wilcox-Brown is offline   Reply With Quote
Old July 9th, 2010, 09:54 PM   #3
So are you actually editing native Canon XF codec files, or does it have to transcode to ProRes?
Barlow Elton is offline   Reply With Quote
Old July 10th, 2010, 04:25 AM   #4
The plugin transcodes MXF to ProRes. Avid supports the native camera files, as I believe does Premiere CS5
If the fie structure is not maintained, the L&T plugin cannot see the MXF files
Nick.
Nick Wilcox-Brown
Old July 10th, 2010, 10:33 AM   #5
Hi Folks,
Can't confirm with FCP's Log and Transfer, but on Adobe CS5, Canon's MXFs files are indeed working.
Downloaded Nick's native MXFs clips last night and imported them into Premiere Pro. All clips (including audio) play fine.
@Nick--I believe all those clips are from the pre-production XF cam; are there downloadable clips from a production, working XF camera?
--JA
Jeff Anselmo is offline   Reply With Quote
Old July 10th, 2010, 12:09 PM   #6
I currently have a XF305 on loan to me.
As for Final Cut, I have FCP 7 (FCS3), and L&T sees the clips off the camera no problem. I can set in and out points too. I will try to capture a 3-5min clip, and see how well L&T scrubs with that.
My NXCAM loaner would lock up Final Cut (force quit needed), scrubbing thru footage.
Michael Assadourian is offline   Reply With Quote
Old July 10th, 2010, 12:39 PM   #7
Jeff, Sorry have not managed to get my hands on a production camera. To my knowledge there are no production clips around at this moment, but I suspect someone here with a new camera will be able to help?
Nick
Old July 10th, 2010, 10:57 PM   #8
Hi Nick,
Thank you for all your work and input on the XF! And really appreciate those clips!
And great work on the Morgan Video; it really showed the usefullness of the XF's stabilizer :)
Best,
--JA
Old July 11th, 2010, 11:23 AM   #9
Nick.
A bit bummed by this, but then it's Apple/FCP and that means QT or nothing at all. ProRes is great but just a huge disk space hog. I'd prefer editing native MXF and then export a sequence to ProRes for better quality retention. Drat.
Gonna take a much closer look at Premiere.
Old July 11th, 2010, 03:21 PM   #10
Avid now looks like a clone of FCP and edits MXF natively....Oh and it supports ProRes too. Just a thought...
I'm sure the radically updated FCP, due at some point forwards will address these issues, but maybe not and perhaps iPhones and iMovie really are the Apple future?
Nick.
Nick Wilcox-Brown
Old July 12th, 2010, 12:50 AM   #11
Nick
Weird! All of a sudden I am able to view the files at Log & Transfer! :-)
Shuf
www.malaysiakini.tv
Old July 15th, 2010, 10:13 AM   #12
Same problem
I'm having the same problem as the original poster. But my files haven't suddenly appeared yet. I have tried everything, but it seems that there is no way to transfer to FCP without the plugin from Canon. We were able to use a new Canon, but there was no cd-rom with software in the package.
As the plugin is nowhere to be found on the internet, could I ask you, Nick, or another well-doer to put it online somewhere? We use FCP so I need the plugin for Mac.
Thanks in advance!
Jeroen Mestdag is offline   Reply
Adorama
(800) 223-2500
New York, NY
New York, NY
Texas Media Systems
(512) 440-1400
Austin, TX
Precision Camera
(800) 677-1023
Austin, TX
VideoGuys
(800) 323-2325
Mineola, NY
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XF Series HD Camcorders
1998-2018 The Digital Video Information Network
