Ghosting on the XF300
I've just been doing some tests on the XF300 on 30p and 24p and I'm getting some ghosting. You know,movements of hands and things like that that leave that trailing effect.
What am I doing wrong? What should I be doing? Is it my shutter speed? |
My first guess would be to turn off noise reduction. That's probably the culprit.
Not like I'm getting with the Panasonic HPX371 is it ? http://www.dvinfo.net/forum/panasoni...ise-issue.html
Milton,
Can we see a clip or couple of stills? I have not noticed anything on my clips. Barlow, there are advantages to leaving NR on auto, especially at higher gain settings (according to Alan Robert's report). |
Are you talking about high shutter stuttering or actual ghosting?
cant tell you much without a screencap
i don't have a clip to hand right now but it's that effect you get when the clip is interlaced. let's say it's a clip of someone waving their arms. the arms leave a very slight trail.
i will try to post a clip later today. |
ghosting. but it's not massive but just enough to be noticeable. |
Mitch,
I get the same thing on my XHA1s when I shoot in 24p with people moving their hands. Here is a link to a video where it happens. I think it may be the back and forth motion. |
24P footage should just look blurred with fast motion, there should never be a double or ghost image. |
Finally got some footage up. Look at the first artist, at the start of his presentation. He waves his hands a bit and leaving that trailing effect.
Try taking a still image in low light at 1/48 or 1/24 second and then wave your arm around. The result WILL be blur.
To freeze a moving object, one has to use a shutter speed of 1/250 or 1/500th minimum ie 10x the speed you are using to shoot smooth video. This is not a camera issue, it is physics. Nick. |
Are using some type of low light or cinema mode that lowers the shutter speed? It looks to me, FWIW, like 24P w/ a 24fps shutter. Normally you'd use a 48fps shutter. |
I agree with Nick and Peter, the wrong shutter speed has been used. That's all that's going on.
Milton, why don't you use Canon's XF Utility software to examine one of the offending clips and let us know what the shutter speed actually was. This is a perfect example of how metadata can be helpful -- and the XF305/300 saves TONS of it. |
