Custom Picture settings
Hi
Anybody know of anyone making Custom Picture settings for the XF305? Mark |
Re: Custom Picture settings
Hi Mark,
These are from Brian: CP files for Canon XF Cameras - Canon XF Video 300/305/100/105 forum on Vimeo I've been using Doug Jensen's CP files (but don't have that info on hand at the moment). For low light settings, I usually turn off CP and adjust in post. Best, |
I have DJ's CP file. Good DR but if I remember correctly his sharpness is way up? The consensus seems to be going the other way from what I read on this forum to avoid IQ issues.. I think mine are at -3 this week!
I run my new XF305 at the 'BBC' settings created by Alan Roberts. Nice and neutral, not too sharp. Great for general use and far nicer than the camera default.
Let me know if you want a CP file. |
I've got my camera set up to Alan's BBC setting as well - (since I spend most of my time at BBC Wales, it's only natural...)
It does indeed give a good neutral look, which can easily be treated in post if required., though I tend to keep the look as it is. |
Dear Nick
I would be interested in the BBC's CP file settings. Do you know whether the settings would work on a Canon XLH1 camera? We will be using both a XLH1 with Nanon-Flash and an XF305... my aim is to try and get a neutral look for both cameras to better match intercutting in post. Any advice would be greatly appreciated. Best regards Didi Schoeman |
I have one of the setting designated as a "BBC" profile. However, I punched-up the color gain a few notches as I felt the material appears a little flat for my taste. All in all, a great setting.
The BBC profile is definitely too sharp, as Lou and I have been discussing on another thread here. Alan's settings work well on static objects (such as a zone plate chart) and are an excellent starting point but if there's fine patterns and motion (!) involved in any way, the detail does need to come down even further to allow for baseband 1080i viewing or SD down-converts.
Hi Didi,
Ohers have said that it is possible to use the CP files on other cameras and it may be worth trying and then doing a side by side comparison. Alternatively, the XHG-1 is effectively the same as your XLH1 with a fixed lens and I would be inclined to use Alan's settings for that camera. They are towards the end of this pdf: http://bit.ly/gnVe4b |
I tried to transfer the files from my XF-300 to the XF-100, but to no avail via the 300's SD card.
The best suggestion is to copy down the profile settings from the Canon Pro series, both past and current, and manually enter the profiles- then save to the SD card. |
Thanks Nick, will have a look at those and play around with various settings.
Andy,
Better looking than the standard 'look' but neutral enough to work well for post-production. If you want a more finished look, then try some of the CPs that have been created by users. |
Nick I have searched but with no success for user made CPs. Any idea where I can find any?
