Creaky Rocker at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XF Series HD Camcorders
Canon XF305, XF205 and XF105 (with SDI), Canon XF300, XF200 and XF100 (without SDI).
Old July 11th, 2011, 11:37 AM   #1
Creaky Rocker
My rocker on my 305 has started to creak, and when pressed fully but gently the plastic structure around it gives a crack loud enough for the mic to pic up in quite conditions..
Am I alone?
Matt Ford is offline   Reply With Quote
Old July 11th, 2011, 12:59 PM   #2
Re: Creaky Rocker
I don't have a 305 but I had to send back my xa10 because the rocker on the handle started to go bad and not work all the time. And I had a xf100 that had a very hard to press and loud record button if your thumb was not perfectly centered on it.
Gerald OConnor is offline   Reply
Adorama
(800) 223-2500
New York, NY
New York, NY
Texas Media Systems
(512) 440-1400
Austin, TX
Precision Camera
(800) 677-1023
Austin, TX
VideoGuys
(800) 323-2325
Mineola, NY
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XF Series HD Camcorders
1998-2018 The Digital Video Information Network
