Would a LANC controller fight a Follow Focus?
Wanting to take my game-plan/play up several notches (still waiting for my xf300), I'm scoping for a follow focus.
What I've had at the back of my mind is that would a LANC controller "crash" the gearing of a ff with the mechanically attached ring gear and the 90deg offset block and tackle. Yes I realise I'd be using these 2 contraptions under different situs and therefore I'm possibly asking a hypothetical question, however I still want to know. Does the xf300 need "ff-free" movement IF the LANC (the same as Robin, I have the Frotti "i", love it) is deployed? If I were to operate the LANC would I smash the internal gearing? TIA Grazie |
Re: Would a LANC controller fight a Follow Focus?
No takers?
Maybe it's too obvious? I still wish to know. Cheers Grazie |
The LANC control has no physical effect on the lens barrel itself, ie, you won't see the barrel turning as you focus via LANC.
One thing I've noticed is that in order for the remote to work properly, you must have the camera switched to both Manual in focus and zoom BEFORE you plug in the remote, otherwise it won't work... |
The focus and zoom on the CF are (I think I can safely say it) servo controled, ie turning the focus/ zoom rings sends an electronic signal to the appropriate servo to do it's thing.
Lanc does the same thing using a slightly more involved data path. Winding the focus ring one way whilst pressing the Lanc controller focus button the other way, the camera servo system will ignore one of the controls untill the first control has stopped sending messages. There's no gears to trash. The only issue you may have is remembering exactly which control turned/ pressed in what direction actually moves the lens which way. CS |
