C300 to XF300 Custom Picture Setting? at DVinfo.net
Old January 4th, 2012, 01:04 PM   #1
I read that there is a custom picture setting for the C300 that attempts to match it with the 5d mkII. Is it possible that that could somehow be used on the XF300?
Just a thought.
Jeff Lower
www.JeffLowerVideo.com
Jeff Lower is offline   Reply With Quote
Old January 4th, 2012, 01:14 PM   #2
Re: C300 to XF300 Custom Picture Setting?
Sorry but no. The preset files for the C300 and XF series are indeed
similar in structure, but are also just slightly different, enough so that
they are incompatible with each other.
Old January 4th, 2012, 01:18 PM   #3
The C300 has a Gamma Table called EOS STD Check out my Gamma tests on Vimeo at
This is EOS std gamma table mimic's the Canon EOS std Gamma found on the 5dmk2 but unfortunately you don't have such a gamma table on the xf300
Mark Moreve is offline   Reply With Quote
Old January 4th, 2012, 06:01 PM   #4
Too bad, that would have been nice. Even without the shallow depth of field, or the low light sensitivity it would have been nice to help match them up a bit easier.
Thanks for the replies.
Jeff Lower
