I am experiencing poor, grainy footage with the Canon XF100, please help ! at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XF Series HD Camcorders
Canon XF305, XF205 and XF105 (with SDI), Canon XF300, XF200 and XF100 (without SDI).
Old July 12th, 2012, 10:38 AM   #1
Hello, I recently purchased a Canon XF100 and went out to test it today. the image quality on the cameras LCD screen is superb , however once I upload the clips onto my computer they go all grainy and are very poor quality. Here is an example:
I recorded this at 50Mbps 1920x1080 50i. I was wondering if anyone had experienced this problem or if anyone knows how to fix it.
Chris Andrews
Chris Andrews is offline   Reply With Quote
Old July 12th, 2012, 11:14 AM   #2
Re: I am experiencing poor, grainy footage with the Canon XF100, please help !
Hi Chris,
Which program mode was used to record this? (P, Tv, Av, etc.)
Have you reviewed this material on an HDTV, by connecting the camcorder via HDMI cable?
Was the ISO setting on Auto?
Search DV Info Net | DV Info Net Sponsors | A Decade (+5) of DVi | ...Tuesday is Soylent Green Day!
Old July 12th, 2012, 11:51 AM   #3
Thanks for your reply, I have plugged the camera in to a HDTV with a HDMI cable and the footage is still pretty grainy.
As to what program mode it was recorded in I don't know I'm afraid , I'm very new to using cameras , I have browsed through all the menus on the XF100 and I cannot find anything to do with program mode.
Also there are no options for ISO adjustments that I can find on the camera or in the manual , but I did have the camera on full manual and I adjusted the aperture, gain, white balance etc and whilst recording the image was great and upon playback on the camera itself the footage looks fine.
Old July 12th, 2012, 12:24 PM   #4
Sorry, my error, ISO = Gain. That was my fault.
What were the specific shutter, aperture and gain values for this clip?
Old July 12th, 2012, 01:03 PM   #5
Right , after finding out exactly what settings everything was on I may have found the problem , the gain was on auto and was very high at 24.0dB, the shutter speed was 1/50 (is that too slow ?) and the aperture was set at F8.0. Do you think these setting could be causing that grainy quality.
Chris
Old July 12th, 2012, 01:20 PM   #6
Yes, the auto gain is the issue.
/Roger
Roger Averdahl is offline   Reply With Quote
Old July 12th, 2012, 02:14 PM   #7
Looks like the problem was the auto gain , thanks for helping me find the problem guys!
Old July 12th, 2012, 02:20 PM   #8
Vortex Media
NEVER use auto-gain under any circumstances. If you must increase the gain because you are in a low-light situation, always do it manually so you are in control of the setting and can choose when it is changed.
1/50th is not too slow for 50i. That's right where it should be under normal shooting conditions.
However, an aperture of f/8 should always be avoided on any 1/3" camcorder due to diffraction. You'll want to try and keep the aperture at f/4 or wider for best image quality. All 1/3" camcorders suffer from the same issue.
You also might want to try shooting 25P since interlaced is a little old-fashioned now. :-)
MASTERING THE CANON XF305 & XF300 CAMCORDERS
I hope that helps get you on the right track.
Old July 12th, 2012, 08:24 PM   #9
Thank you for those precious tips Doug, I never realized that f/8 will already lead to poor quality images.
Sam Young is offline   Reply With Quote
Old July 12th, 2012, 09:32 PM   #10
These settings will fix you up:
In Color Matrix settings dial R-G to -8.
Set sharpness to -5 and Coring to +8.
Also set Noise Reduction to 2.
Don't go over +6 gain
Use 1/25 only in very low light.
Mark Andersson is offline   Reply With Quote
Old July 14th, 2012, 06:56 AM   #11
Doug, your training videos look great. Do you have a downloadable option or only physical DVD?
Joseph Kitzmiller is offline   Reply With Quote
Old July 14th, 2012, 03:07 PM   #12
Vortex Media
Hi Joseph, just DVDs at this time.
Old July 14th, 2012, 03:21 PM   #13
You could pick up a ND filter to keep your Iris less than f8 in bright conditions such as:
B+W 58mm 501 Graduated 0.3 ND Filter 65-063807 B&H Photo Video
Adorama
(800) 223-2500
New York, NY
New York, NY
Texas Media Systems
(512) 440-1400
Austin, TX
Precision Camera
(800) 677-1023
Austin, TX
VideoGuys
(800) 323-2325
Mineola, NY
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XF Series HD Camcorders
1998-2018 The Digital Video Information Network
