Shutter angle at DVinfo.net
Old October 13th, 2012, 06:46 AM   #1
Shutter angle
Does anyone know where I can find some info about shutter speed/angle and the xf100 (or xf300)
I know for 1/50 (as i am in Pal-land) the angle should be 173 degrees but there is no such value in the camera.
Closest is 180 which is for 24fps.
Am I missing something here.
Thanks.
Old October 13th, 2012, 09:39 AM   #2
Re: Shutter angle
Are you shooting 24fps or 25? The 173° shutter is to reduce flickering of 50hz lights when shooting 24fps. As you say you are in PAL-land, you're probably shooting 25fps, and 180° is fine.
Bill Engeler is offline   Reply With Quote
Old October 14th, 2012, 06:20 AM   #3
Re: Shutter angle
OK thanks.
But i am also looking for some indepth information in relation to videocamera's
Old October 14th, 2012, 06:32 PM   #4
Re: Shutter angle
Doug Jenson touched on it a while back. there wasn't a lot on this thread. Maybe it will be helpful.
http://www.dvinfo.net/forum/canon-xf...ter-angle.html
Al
Upper left hand corner of the map
Al Bergstein is offline   Reply With Quote
Old October 15th, 2012, 12:59 AM   #5
Re: Shutter angle
I wrote an article about ti here:
Shutter, shutter speed and shutter angle. |
The key thing to note is that the angle purely defines the shutter speed, which with angle is related to and changes according to the frame rate while speed in seconds is fixed and does not change if you change frame rate. The actual operation of the shutter is identical whichever method of displaying the speed you use. Really on a video camera fractions of a second is far more useful than degrees, degrees is just fashionable because it sounds cool but when your trying to sync shutters to mains frequencies or lighting frequencies degrees are a PITA.
Old October 16th, 2012, 04:10 AM   #6
Re: Shutter angle
Both thanks for the articles.
Old October 16th, 2012, 11:58 AM   #7
Re: Shutter angle
Hi Ann!
I believe in the canon's XF series lerning videos there is one regarding shutter. You may take a look at those videos.
Canon DLC: Gallery: XF Professional Camcorder Tutorials
Rodolfo Pena is offline   Reply With Quote
Old October 16th, 2012, 01:48 PM   #8
Re: Shutter angle
Thanks, that is great.
Ann Bens is offline   Reply
