Canon XF100 MXF File Question at DVinfo.net
Old May 27th, 2013, 11:10 AM   #1
Hello All,
I'm thinking about getting a Canon XF100. I currently use Sony Vegas Movie Studio Platinum 12 to edit my videos, which will not work with .MXF files.
How do I transcode .MXF files to MPEG-2 or some other format my NLE can use? I've looked just about everywhere on the web and can't find a clear-cut answer.
Steve Struthers is offline   Reply With Quote
Old May 27th, 2013, 02:19 PM   #2
Re: Canon XF100 MXF File Question
Are you sure that Platinum won't take MXF? If not, your best choice might be to upgrade to the full Vegas pro product, which does work with them.
Other than that, I would assume you might find a tool that transcodes to something that platinum takes, but I don't know what that is. You'd have to look at the reqs for the product and find out what matches. There are many tools that can do transcoding out there. Some free.
Al Bergstein is offline   Reply With Quote
Old May 27th, 2013, 03:39 PM   #3
Video Converter Ultimate by Wondershare will convert .MXF files to .AVI, .MP4, .MP3, .WMV, .DIVX, .MOV, iPad 2, the new iPad and iPhone 4 file types.
Priced at $50.
Wondershare Video Converter Ultimate
Old May 28th, 2013, 04:17 AM   #4
Video Converter: 4.2.2 and 50 mbps poef gone.
I would go for a NLE upgrade.
ACE Premiere Pro CC
Adobe Community Professional
Old May 29th, 2013, 05:59 PM   #5
A while back when FCPX first came out and it was discovered that it would not accept MXF files, a guy called Rune Espensen wrote a program called XFCPX which simply changed the container from MXF to MOV without altering the file contents. I don't know if MOV is any more convenient for you, but if it is, this program, which can be found on a search for "xfcpx" , is quick and clean.
Scott Hiddelston is offline   Reply With Quote
Old June 3rd, 2013, 01:35 AM   #6
Hi
I use an XF105 and use a free program called MediaCoder. This little converter works exceptionally well and is very fast. Just be sure to combine muiltilpe clips using the XF Utility before doing the conversion.
Settings for Mediacoder:
Video - check the Copy Video checkbox
Audio - copy the same audio characteristics as the original file
Container - select mpeg-2
Do a test with a small file to make sure that the conversion works for you.
Afzal Thayab is offline   Reply With Quote
Old June 3rd, 2013, 07:37 AM   #7
I also ran into this issue when I got my XF105. Sony Vegas Movie Studio 10 could not handle the files; I tried the various converters but they were slow and degraded quality. I upgraded to Sony Vegas Pro 12 and it all works great.
Gary Yek is offline   Reply
