August 30th, 2014, 04:27 AM | #1 |
Canon XF305 external recorder
Hi,
I will be shooting a 2 day conference and I'm trying to figure out how I can manage recording such a long event. I normally just record to CF cards but for 2 days I need another solution. Any recommendations? |
August 30th, 2014, 06:43 AM | #2 |
Re: Canon XF305 external recorder
One option that could work with the XF-305.
If you can beg, borrow or steal, or hire an Atomos Samurai Blade with a 500GB drive you would have a pretty good solution for long record sessions. If you are not running around madly this can use a cheapish, around $70 hard drive, doesn't need to be an SSD and it will give around twelve hours recording of ProRes LT. ProRes can be edited on either Mac or Windoz so no real issues there. Three Sony NP-F970 batteries will power a Samurai Blade for a day. I recently did a non-stop gig of 4hr 55 mins record time and the whole session used just one F970 battery. It was nearly flat but had that have happened it would have switched over to the second battery automatically. You can hot swap batteries on the Blade. All in all I find this combo is great for long corporate gigs, concerts etc in either SD or HD. Samurai Blade | Atomos Chris Young CYV Productions Sydney |
August 30th, 2014, 01:29 PM | #3 |
+1 on the Samurai. I use the same setup of a 305 and Samurai Blade. I love the thing.
August 31st, 2014, 05:23 AM | #4 |
Thanks a bunch!
August 31st, 2014, 09:25 AM | #5 |
+1 on the Blade. A great product. I use an SSD with it.
Al Upper left hand corner of the map |
August 31st, 2014, 11:32 AM | #6 |
I did a two-day conference with an XF305 and XF105. I have 4 CF cards for each camera.
As each card filled up, I would take it out and load it onto a laptop equipped with an external USB 3 card reader. A previously-formatted empty card would take its place. At break times, I would copy the most-recently copied contents from the laptop hard drive to an external USB 3 hard drive, so I would have two copies. Also, I would format any cards that had been successfully copied so they would be ready to go in the rotation. |
September 3rd, 2014, 04:46 AM | #7 | |
September 3rd, 2014, 06:30 PM | #8 |
Kathy, I also have a 305 and a 105.
I use both 128 gigs and 64 gig cards 64 gig is 163 minutes of HD video (1920-1080) 50 mbps 128 would be 326 minutes. Get a USB3 CF card reader (if you have a computer that uses usb3). It will speed it up by 10 times over usb2 the transfer speed. During the breaks is when I start to transfer files. 4 CF cards will do (even 64 gigs), at nanoflash dot com you can get a 128 gig CF for $200. I just got one for my last event. Good luck, James
James Redmond; Dynamic Videos, Inc. Rogers, AR USA |
September 4th, 2014, 01:47 PM | #9 |
James ... good info on CF cards. I just purchased the XF200 and was wondering about the size cards I needed.
Just one correction though on the Nano site ... I believe that should be dot net. |
September 5th, 2014, 05:42 PM | #10 | |
I don't like having one big card. In case the card fails (or you accidentally wipe it) you've lost everything. |
