Canon XF300- HDMI to SDI converter at DVinfo.net
Old October 12th, 2014, 11:36 PM   #1
Hi guys. I'm sure this has been answered before...
I have been doing live feeds to screens in some conferences and live shows and I have used the BNC connection on the XF300 and the SD signal has been acceptable...
but recently I did a bigger show and the screens were really gigantic and the SD quality out of the BNC was painful to watch! So..the AV company told me that they need an SDI HD signal next time..
so I guess I will have to get a HDMI to SDI that lets me give the AV company an HD signal....
which one would you recommend that is affordable? Any restrictions so far as frame rates etc..
I definitely need one..(I wish I could have afforded the XF305!)
thanks
Erick
http://www.fandangovideo.com
Canon C100 mark 2, Canon XF300 & XF100, Canon 90D, Sony a6400,Ronin S etc etc
Erick Perdomo is offline   Reply With Quote
Old October 13th, 2014, 08:31 AM   #2
Re: Canon XF300- HDMI to SDI converter
Without a shade of a doubt I would consider the Atomos converters. Pretty well priced, small, high quality and well made. They make HDMI to SDI and vic-a-versa. The model you would be after would be the Connect H2S. This is HDMI in with two HD-SDI out. They have about an hour's run time on an internal battery or around ten hours on a small Sony camcorder battery. Just tape it to the tripod leg or even the camera handle if you have to be hand held. Check them out here.
Connect Converters | Atomos
and here
Atomos Connect H2S Converter with 2600mAh Battery ATOMH2S002 B&H
Chris Young
CYV Productions
Sydney
Old October 13th, 2014, 11:50 AM   #3
Hi Erick,
I have the Atomos convertor. It works well. Just make sure your monitor can handle a 3G-SDI converted signal and you should be good to go. I bought this one, http://www.bhphotovideo.com/c/product/964935-REG/atomos_atomh2s002_1xh2s_converter_1_2600mah.html
Old October 13th, 2014, 04:38 PM   #4
awesome! thanks so much for the help...I will get it for sure- so far very happy with my Canon XF300 and with this adaptor I wil also be able to use the XF100 to provide a HD live feed if needed.
thanks brothers!
Erick
Old October 14th, 2014, 01:18 PM   #5
Both AJA and Black Magic make converters as well that work great.
Mark Koha is offline   Reply With Quote
Old October 14th, 2014, 08:40 PM   #6
Right..AJA and Black Magic...I like the concept of the Atomos because it uses a common Sony Battery. Does any other converter have a similar concept? I will try to get the Atomos locally here in Toronto and try it. If I like it, I will put some velcro on the bottom of it so that I can attach it to my camera or a tripod if needed. Old school rules!
thanks
E
Old November 17th, 2014, 11:29 PM   #7
Images: 57
Another vote for Atmos products.
Pete Ferling http://ferling.net It's never a mistake if you learn something new from it.
Peter Ferling is offline   Reply With Quote
Old November 18th, 2014, 09:25 AM   #8
And another. I use my it with my Ninja which supports the Canon 5D batteries.
Al
Upper left hand corner of the map
Al Bergstein is offline   Reply
