On camera LCD?
One think I don't like about the A1 is the mini-LCD.
Can anyone recommend a good on camera LCD display? I've heard of the Marshalls and Variazooms, but can't find any real user reviews. I'm looking to spend under $500 (but more like $300). Anybody have any opinions on this? Thanks, Howard |
If your budget is $300-$500, then save your money and use the on camera monitoring. I have the marshall, and in my opinion this is entry level for HD field work. Panasonic makes a very nice HD field monitor, but it is about as much as you paid for your camera.
Well that is kind of depressing.
Thanks for the info. Howard |
What do u guys think of the IKAN 8" HD MONITOR.
ye i would like to know
ikan 9.2" LCD Monitor Wide 16:9 Format $639 - Diagonal 9.2 " TFT - LCD - LCD Brightness: 300cd/m2 - Resolution: 800 x 480 - Contrast Ratio: 250:1 - Viewing angles: 65/65(R/L) - Operating Volts: DC 11-13V - Power Consumption: <9W - Operating Temp.: 0-65C - Storage Temp: -25-70C - Dimension: 9.6"x6.7"x1.5" - Weight (lbs) 1.2 Ikan 8" LCD Monitor Wide 16:9 Format $729 Specifications -Diagonal 8" TFT - LCD - LCD Brightness: 400cd/m2- - Contrast Ratio: 200:1 - Resolution: 800 x 480 - Up to 1024 x 768 - Viewing angles: 65/65(R/L) - Operating Volts: DC 11-13V - Power Consumption: = 10W - Operating Temp.: 0-65C - Storage Temp: -25-70C - Dimension: 8.1"x5.7"x1.2" - Weight (lbs) 1.05 ikan V8000HD 8" TFT LCD Monitor $1149 Application Video and Computer Monitoring LCD Size 8" Video System NTSC/PAL Picture Elements 800 x 480 Input and Output Connectors Component Video: BNC (x1) Composite Video: BNC (x1 Input, x1 Output) S-Video: Mini DIN (x1) Analog Audio: RCA Stereo (x2 Inputs) Picture Controls Brightness, Contrast, RGB Value Remote Control Yes Power Requirements Not Specified By Manufacturer Power Consumption Not Specified By Manufacturer Dimensions (WxHxD) 8 x 5.5 x 1.5" (20.3 x 14 x 3.8 cm) Weight 1.2 lb (0.5 kg) all of this has a resolution of 800x400 how come the price difference ? (prices are in australian dollars) which one is good ? i understand that the v8000hd is the only one for high defination but the rest has the same resolution so am a bit confused. please ignore my ignorance as am just learning. thanks for all the help. |
I would just be really, really wary of anything less than $1K (probably $2K to be realistic). There is a whole entire forum here on monitors, BTW, and most of the worthy HD monitors have likely been reviewed or described there.
i have started a new thread in the SDTV/HDTV Video Monitor Forum so if someone wants to check out the replies here's the link
http://www.dvinfo.net/conf/showthrea...524#post782524 |
