Audio recorded on seperate tracks?
I'm filming an event in a huge auditorium tonight. If I have XLR 1 coming off the sound board and my external shotgun going into XLR 2 will I be able to seperate these audio sources on the tape later, or will it just mix them at the levels I have set?
I'd like to have the option of taking out the ambient sound sometimes and just using the XLR 1 (mixer) audio as this is a spoken word event. |
You can run two separate channels in, but be careful of the little switch on the right over the XLR inputs. It's a bit counterintuitive. If it's set to Ch. 1/2, that's not good. If it's set to Ch. 1, then your XLR 1 will go to Ch. 1 and XLR 2 to Ch. 2. Also, you can not record line in to one channel in and mic in to the other. All you get is mic or line, no and/or. So you'll have to get a mic level out from the mixer, or run your shotgun through the mixer if you can't do that so you can have 2 line levels.
Audio is my weak point
I do not understand mic level out from the mixer. What would be the difference between line and mic level out? I cannot run my shotgun through the mixer, that is for sure.
So what do I need coming from the mixer. My intention was to run an XLR out from the mixer. What can I do to differentiate between mic and line out from the mixer? Thanks for your quick response. |
Well in that case the mixer would have to be giving you a "mic" out signal, rather than a "line" out. That may or may not be possible depending on if they (whoever is on the soundboard) are sending line out for something else.
Most mixers can output either a mic level or line level. If you are going to go directly into the camera with your shotgun mic, then you have to be at mic level for both inputs. So you'll need to check in advance if the soundman can give you a mic level output from his mixer. If all he can do is line level, then your choice would be to rent/borrow a portable mixer and run your shotgun through that to get line level.
Hi Brian.........
If you're getting line from the board, I believe you can fit a 50db attentuator to the line to knock it down to mic level for the camera.
I think it's 50, might want to trawl a few of the audio threads to double check that. This is the sort of thing I mean. http://www.bhphotovideo.com/c/produc...ttenuator.html tho' interestingly, all of the ones on B&H say "MIC" not "line". CS |
In any case, if you can test as much of the various configurations and option as you can before the event to be sure it works and that you are comfortable with it. |
With a bit of luck you might be able to get your local electronic shop to make you up a basic attenuator. There's nearly always one young gun in these places who has all the knowledge and enthusiasm.
Simply it would be a small potentiometer. You're looking to match a 600 ohm mic input impedance. It's not a major job and you can experiment with potentiometer values. Start with maybe a 10k ohm? (they're pretty cheap) until you're happy with the result. Bottom line is you won't harm the A1 as we're talking small signal stuff anyway. |
In case any of you likes to make this stuff, here's a guide. The line to mic values are at the bottom of the table.
http://www.uneeda-audio.com/pads/ |
how about using the A1 ATn? can that be enough and is it possible to get distorted sound from the board. Thx
the A1's MIC ATT setting, if that is what you are asking about, is a means of reducing the gain of the input stage of the mic preamp (by about 20 dB) to accommodate higher output microphones and/or loud venues. It reduces the chance of the audio signal being clipped in the preamps. In general it does not provide sufficient attenuation to accommodate a line-level signal.
It also has the additional benefit of reducing the noise floor, so it is the better of the MIC settings to use if your microphones (or other source) have sufficient output to allow you to obtain normal record levels. |
Is it possible to use the A1 ATT in addition to line ATT
If I understand the question correctly - The ATT setting in the XH-A1 is independent of any external attenuators you might add to the line output from a mixer, etc. so you could have external and internal attenuation in effect at the same time.
However, I suspect that you would only use that combination if necessary to keep the recorded audio levels in the desire range. |
