XH-A1 & the HD Portable DTE Recorders
I am contemplating purchasing a Focus Enhancements FS-4 HD portable DTE recorder. There are a couple of choices that I have noticed. There is a "Canon" Firestore FSC-HD recorder that is about $550 more ($1150) than the Focus unit ($699). It appears that they are both manufactured by Focus. Given the huge price difference there must be a benefit to the Canon??? Does anyone know why and what the difference is?
Also I am wondering if anyone actually considers these devices useful? |
The FS-C is specifically designed to be compatible with all the Canon HD and SD modes (30F/24F/60i). Any updates made to Canon cameras will be reflected in the firmware for the FS-C model of their DTE line, but may not be reflected in any of the others. If you want to maintain compatibility with Canon cameras, you might want to think about getting the FS-C.
That said... if you'll be sticking with the A1, I doubt we'll see any added features on that camera any time soon. :-( |
Do you know whether the Focus (cheaper one) will work with 24F and 30F modes as well?
Guy,
When I was shopping for a DTE, I asked the same question from FocusEnhancements. Here is part of the reply I got. As you can see, they recommend the FS-C for Canon cameras: Quote:
Hope this helps. |
Well that makes sense. I am going with the Canon one!
Thanks for the advice. |
I too am interested in the Firestore units, but have a couple of questions before i make any final decisions.
1: Are they reliable enough to work with without the need to use a tape back up? 2: Will these units work ok at low temperatures, say -30deg C? This last question is probably the most important one for me as i will be shooting in the snow. Thanks in advance for any advice. Bryce |
Bryce,
I can't answer question #2, as I live in Southern California, and it's very hot here! As far as answering the reliability question, all I can say is that unlike tapes, where I've had dropouts and errors in the MPEG stream (as reported by Premier Pro CS3), I've never suffered the same problems with the FS-C. One thing to remember though, is that the Firestore products work off the firewire connector on the camera. The instant you press the RECORD button on the camera to stop filming, the Firestore products also stop recording. However, the camera takes some time to process the captured footage and send it out through the firewire port. It takes about 2 seconds to "flush" the footage throught the camera's firewire port. What this means is, if you stop filming right at the end of the footage you want to capture, the Firestore will not save the last 2 seconds. Therefore, when using a Firestore product (or at least, the FS-C with the Canon A1), you MUST remember to keep filming for 2 seconds AFTER you'd normally stop filming if you want to be sure of getting everything on the DTE recorder. A real world example of the above, would be filming someone counting down from 5 to 1, in one second intervals. If you press the RECORD button on the A1 to stop capturing footage when the subject says "1", the DTE will record only "5, 4, 3" |
So just to clarify, the FS-4 Pro HD will record to Quicktime (from an XH-A1) only in 60i, and will not record to Quicktime in 24f and 30f modes, correct?
Does anyone know what modes the FS-5 will record? |
