HD Monitoring with XH A1
Pretty simple question...is it possible to monitor through the component cables to a HD TV, without seeing the menu display if it is still on in LCD?
I want to be able to see the menu display in the LCD, but have it turned off on the monitor. |
Hi Ian...........
I believe you need:
Manual Page 86, "Hiding/ Showing the Displays on the TV Screen" [Menu - Display Setup - TV Screen = Off] The default during recording appears to be [On]. The default during playback is [Off]. CS |
Be careful when you start playing with the settings. There are options that will allow you to display the settings which will also record the setting to your tape. This means that when you play back the tape, the settings will appear with the captured footage.
Hey everyone, thanks for the info, that helps a lot! I'll check it out.
ok got it to work, sweet! no menu on the monitor.
Next up, trying to calibrate the monitor to the color bars on the cam.... Seems a little tricky. I looked online for some web sites on how to set them up. I found this write up. - Color Bars Only thing is one of the bar colors is showing up differently than the bars image on the site. The third bar in on the bottom appears to be a violet color. But on my A1 when I output the bars it appears to be a lot more blue. All other bars look spot on....I can get it to look more violet on the HD monitor but I have to crank the setting way out. Also in the camera LCD it appears to be blue and not violet. When I adjust the lcd settings it wont even really go to the violet without making the LCD look really bad. So I am wondering if maybe the bar set is a little different? Anyone have any thoughts? |
The flip out LCD is not necessarily 100% color acurate so don't get crazy trying to make it look right there. Rather, shoot some color bars and check with a vector scope and adjust your camera to make sure that everything is lined up properly. You can make adjustments with the custom presets as well. White blancing will also alter the look. The A1 is definately not a point and shoot camera, but once set up properly, can produce some great images.
One last thought, purples are difficult to reproduce accurately. |
As Marcel said, don't lose sanity trying to eyeball & correct the purple/violet issue displayed on the A1's LCD. Certain shades of those colors don't display properly on the LCD, but will be correctly displayed on a connected monitor. About the only thing you could do regarding color bars and the LCD is adjust for correct luma levels using the pluge pattern.
