Question about a deck for the A1s
Hey all,
I'm planning my budget for a low-budget feature. The look and feel of the film can be achieved by using the XH-A1s. However, I don't have a lot of time to shoot this - I'll only have about 3 weeks. So instead of shooting on one camera 3 times, I'm going to try 3 cameras to capture the "good take" once. I don't want to sacrifice quality though and I do know about the camera itself and the 24f recording format. However to get the footage into our field laptop, I was thinking of getting the XH-G1s because it has the jack pack. Then I can capture using HD SDI connection. That is WAY more expensive though. So then I thought - is there a deck that I can capture from? I checked on Canon's website but didn't see one. I'm trying to save some money here and if I can purchase 3 A1s cameras instead of 3 G1s cameras, then I'm going to save about 9k. Then if there's a deck out there that does handle 24f then I can get that for hopefully around 3k. So in the end I've saved 6k. Any recommendations? |
Ooooh.. I think I just figured it out. I can buy 2 xh-a1s cameras and 1 xh-g1s cameras and use the G1s for my capture camera. Does anyone see an issue with that?
There'd be no advantage to having the XH G1 model for the HDSDI if the other two XH A1 cameras are passing their recorded HDV footage via 1394 (firewire) to the G1 for transfer. If you want to do live switching, you'll need all G1 models and the additional switching hardware. One A1 and two G1 models can use the timecode from the A1 to synch but you'll still have the A1 recording to tape or a laptop at HDV quality.
Hi Adam.........
OK, I'll bite, tho' think I really should know better.
Let me see: "Low budget feature". So, we're possibly already up for three G1s's (presumably with operators, unless they work by some mysterious remote control), a deck, HD - SDI equipped laptop(s), with operator(s). Then we have "instead of one camera 3 times (Huh?) 3 cameras to capture the "good take" (Huh again?). Lost me on that one. Unless each camera is shooting a completly different scene to the other two (we now have 3 Directors, 3 lots of talent and 3 complete crews???) a "bad take" is going to be the same "bad take" on each camera, no? (or did I miss something at film school?) Which brings me back to this HD - SDI and deck thing. [You know, the further I go with this, the more I get the feeling someone's slipped me a tab of acid or it's one heck of a leg pull] HD - SDI is designed to take full, uncompressed "live" ( I stress "LIVE", not from the tape) video to a suitably equipped HD - SDI ingest machine. If you want HD - SDI then all camera's and ingest equipment must be providing/ receiving "LIVE" feeds, not taking it off the tape, because once it's on the tape it's compressed HDV, not uncompressed "live". If you're writing it to the tape, what's the point of HD - SDI? It's no longer live nor uncompressed, so you might as well save tens of thousands of $$$ and use Firewire like most everybody else. Also, if you're writing it to the tape(s), the only deck(s) required are your trio of camera's, presuming you aren't intending to set some sort of record by shooting 24 hours per day every day with all 3 cameras, in which case you'll just have to slum it with a trio of HV20/ 30/ 40's like us plebs (tho' this does imply, by my count, you're up to 9 complete crews running 3 shifts each on the three cameras - getting a tad up there for a "low budget" production, no?). Recommendations? I'd really rather not. CS |
thanks! |
Hmmm.........
I appologise if I appeared to come over a bit strong, but for someone talking of doing what you are, your apparent ignorance of the equipment is a trifle scary.
Leaving everything else aside, nobody just picks up a A1/G1 (s) (or even 3) and makes a movie straight out of the box. I take it you're to be the director? The best decision as director you can make at this point is to stop talking cameras and get an experienced DOP on the job and ask him/ her what you should be shooting with and how. Knowing every trick to get the best out of a camera is a long learning process, you haven't got anywhere near the time if this has a 3 week deadline. Sure, if you try, you'll get video, but it will be a case of: "It's video, Jim, but not as we know it" and unless that's really where you want to be going, don't do it. With a $300k budget you really should have budgeted for a DOP and the best sound guy you can afford - as long as the script will stand scrutiny and the director has some semblence of common sense, those two people can make the difference between zero and hero. CS |
This may be a stupid question, but if you have one camera set up on wide and two over the shoulders, all shooting at the same time, do you plan on erasing the cameras from the recorded footage in post?
Er, where?
The best I've found so far is this: Scott Billups Tests Canon’s XL H1 for Motion-Picture Production where such a claim, as far as I can make out, is not made. Going to take a bit of grey cell pounding to come to terms with a digital transmission using method A being superior to method B when they're both transferring identical digital data. If you can point out the article I'll take a bash at it. CS |
If it is any better it's going to be negligible. As one of the posts said, the quality you've seen from the camera is via firewire and looks great.
Well, "negligible" is a highly relative term. For some folks it will be negligible, for others it will be significant... and both viewpoints are legitimate. Barlow Elton leaned toward negligible, while Scott Billups leaned toward significant, and I respect both of their evaluations highly. Anyway here are the previous discussions about the advantages to SDI capture of HDV recordings:
http://www.dvinfo.net/conf/canon-xh-...questions.html -- posts #6, #8, #11 and on from there. http://www.dvinfo.net/conf/sony-hvr-...hdmi-v1-2.html -- posts #17 through #20 http://www.dvinfo.net/conf/canon-xl-...t-quality.html -- posts #104, #105, #106 The reference I make to a conversation with Billups happened at CineGear 2006 in Hollywood, where we chatted at length about it following his hands-on tests of the XL H1. Hope this helps, |
