Problem with downconverting
I just shot some clips in HDV (50i) and wanted to downconvert them to SD in camera. I set the Playback Standard option to HDV and HD Downconvert option to ON. When i connected the firewire cable these options became greyed out and when I opened premiere pro 1.5.1 project (i used DV widescreen template) my camera returned the message PLAYBACK STD LOCKED INCOMPATIBLE VIDEO INPUT which according to the manual means that i attempted to input video signal in a standard different from that set. Am I doing something wrong?
Thanks in advance |
The menu option choices such as Playback Standard, etc. need to be made before connecting via FireWire.
Thanks Chris but thats exactly what I did. Made the choices and than connected the firewire cable.
Ok so i figured it out. I can capture the DV footage using the camera's downconvert option with no problem. The message shows up later when I close the capture window and click in the timeline window which is completely understandable as video signal then is different from the playback standard set in camera.
However I have one more probably silly question. When I played back the captured DV files in Windows Media Player I noticed in the properties that the aspect ratio of the file is 4:3 actual, 16:9 displayed. Is this correct? |
im subscirbing cause im going to be doing the same thing once i get my camera
Thanks Tom
