-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Vertical Light (Not)Fantastic (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/88783-vertical-light-not-fantastic.html)
Ian Henderson March 12th, 2007 04:11 PM
My partner and I were fiddling on the beach with our new A1 this evening, seeing what it is capable of over-exposing into the sun as it was setting, and noticed vertical lines appearing from over-bright light sources. Here's a clip I took as it was getting dark on the road just up from the beach on +6 gain, and the lines can be seen again.
Is this something I need to work around (i.e. a limitation of the format), being careful not to overexpose bright light sources, is it a question of settings being up the pole, or is there a problem with my camera?
http://www.thinkteam.co.za/vertical.mov
BTW - we were on 25f, auto white balance, +6 gain
Doug Graham March 12th, 2007 08:18 PM
That's "vertical smear", and it's typical behavior for any CCD image sensor, not just HDV camcorders.
Ian Henderson March 12th, 2007 11:51 PM
So *that's* what vertical smear is then... Is it a live with it situation, or how do people handle it, or lessen its effects?
Doug Graham March 13th, 2007 09:54 AM
1. Live with it.
2. Avoid having bright point sources of light in the shot.
3. Make believe you planned it that way, by using a multipoint star filter on the lens.
4. Use a camera with a CMOS imager instead of a CCD. CMOS chips exhibit far less vertical smear.
Lou Bruno March 13th, 2007 10:56 PM
Agree............the CMOS chips in my HV-10 exhibits little smear. The CCD chips in my XH-A1 and my XL2 display the usual CCD vertical lines.
NOTE: Be careful of reflections from water and chrome objects such as car bumpers. Use a polarizer filter for the above.
Originally Posted by Doug Graham (Post 640940)
1. Live with it.
