XH A1 Head Cleaning
Hi,
I thought I should have a head cleaning tape. The only one at the local store was a TDK MiniDV Head Cleaner (TDK CLDVMEA). It has no mention of being a 'wet' or 'dry' type and TDK web site is no better. Anyone know if this cleaning tape is OK with XH A1? Additionally, it is write protected and says to use in play mode. Does play mode clean both record and playback heads? I had heard on another thread that there are two seperate heads - record and playback. |
It should be okay to use; brand really doesn't matter with a head cleaner. Five or six seconds is all; no more than that. Play in VCR mode. It'll get the job done.
I believe that you will find that Canon MiniDV has two heads on opposite sides of the drum (1/2 turn away from each other). They are dual purpose, for record or play depending on the mode you are using. |
dry or wet?
I was wondering the same thing because the A1 manual explicitly says to use "dry" cleaning tapes only. I have a sony DVM12CLD mini dv cleaning tape but it also doesn't say on the package if it is dry or wet, and i cant find any info on sony's site or anywhere else. Does anybody know of a good dry cleaning tape?
Back in the day, these were common in the VHS/Betamax market. Most if not all would gummy up your heads no matter what they claimed. I've yet to see a similar product crop up regarding miniDV. Just use a name brand mini cleaning tape & you should be fine. Bill |
Thanks Bill,
That clears up the confusion. David |
Adding to the original question
I just got a few A1s and have a related head cleaning question. How often should you clean them. If you wait till you start getting drop outs you will be screwed since dropout in HDV are much worse than SD land. When is it time. I don't want to clean them too often and shorten their lives.
Duh....of course frequently. But how frequently....just wondering if anyone has a feel for it. A friend who used to own GL2s cleaned his heads before every wedding and wore out the cams in just a year or two. I don't want to go down that road....I just don't want to wait for dropouts to clean them cause then it's too late.
The frequency really depends on the environment in which you shoot as well as the number of hrs. For example - I shoot motorcycle videos and am constantly out at the track or on open roads with wind blowing up dirt and debris. I run my cleaner for 6-8 seconds about every 3-4 tapes under these conditions. Indoor shooting I clean about every 10-15 tapes
The heads on my DVX lasted 1400 hrs at the rate |
